How many turns? I am worried the wedge may drop off if I unscrew too much.With the bolt loosened a few turns
Don't worry, you'll be able to retrieve it with a bit of poking with a poky thing.How many turns? I am worried the wedge may drop off if I unscrew too much.
2 or 3 - enough for the wedge to be able to pop out so it can move up and down the steerer tube. then set it at correct height and tighten it back up againHow many turns? I am worried the wedge may drop off if I unscrew too much.
Well, if you break it getting it undone, you know who to call.But one of them I can't move at the moment.
Yes try the nut on the other side as if too tight it can stop the qr workingYesterday, I made some progress on adjusting my bike. Today I have hit a brick wall.
1) NOT FIXED: Stuck QR lever on front wheel. Tried the ring spanner technique. It bent the spanner!
Question: Should I try the nut on the other side of the wheel?
2) NOW FIXED: Raising the handlebars. Unscrewed the quill stem bolt by 3 turns, bashed down with a hammer handle. Could wiggle the bolt around, it doesn't seem stuck.
Tried to free the quill stem from the steerer tube, by holding the front wheels and rotating the handlebars. No luck there, I stopped as I was worried about bending the front wheel.
Unscrewed the cap and washer on the big nut, which exposed the place where the stem and steerer tube meet. Scraped out any muck and tried a couple of rounds of penetrating fluid. Still not able to free the stem.
Went inside and did the crossword for 20 mins. Then was able to free up the stem.
Question: How much can I safely raise the bars by? There are some ||| markings after about an inch.
QRs are sometimes fitted incorectly. Pist close up pic so we can see position of cam lever.> As for the QRs, I've probably got my originals here somewhere if you'd like them. Just postage. <
The quick release levers are in OK condition. But one of them I can't move at the moment.
