Frame painting
U
User32269
If you were to either use wire wool or a Scotchbrite pad to clean/ polish your frame to the finish you require, degrease it, but do not touch it with bare hands and then coat it with a clear lacquer it should be okay. You will need to make sure that you do it on a warm day otherwise moisture may get onto the frame before you lacquer it.
That was my original thinking. May well go down that route, will see how frame comes up. Cheers.
lutonloony
torbay
Once stripped apply the odd dab of brown paint to simulate rust then clear lacquer . Seems to be what the "rat look" car boys do
