Soltydog
- near Hornsea
I must have low torque then, nothing to do with being a lard arseHardly new is it !..... Torque is what people want to know on Ebikes.
Low torque, crap on hills.
Fair do's - wasn't being entirely serious - important info I guess for folks who have a need for these bikes - I guess to me it is a term that smacks of petrolhead macho stuff. I'm still getting to grips with sorting dodgy shifting on my triple.
I’ve only tested it off road on full power where I need the full 1100 lumens, it will run at 450 lumens for 2hrs 50mins and with the battery pack 9hrs. Or you can run it on a 150 lumen flash or pulse mode for 57 hours in total.1 hr 15 mins?
Not sure where that label "infinite light" comes from.
IMO its a really good buy.
Just measured it at 420mm.One question for you @Spiderweb how long is the supplied cable that goes between the light and the battery pack please
Shame as that's not long enough to go along the top tube and under the saddleJust measured it at 420mm.
It's meant to strap to the top tube (it has a rubber pad that sits against the frame) but it would be a good idea to have a longer lead so it could strap under the seat or even into a seat pack or saddle bag.Shame as that's not long enough to go along the top tube and under the saddle
1 hr 15 mins?
Remind me not to buy an infinite distance bike from them.I think it means you can change the battery!
Does it use a generic micro-USB cable? You can get long cheap cables from a large online store that feature singing boxes in their adverts (which doesn’t freak me out at all...) and ships worldwide.It's meant to strap to the top tube (it has a rubber pad that sits against the frame) but it would be a good idea to have a longer lead so it could strap under the seat or even into a seat pack or saddle bag.
You don’t use the USB cable on the bike, that’s plugs into a different port and is just used for charging.Does it use a generic micro-USB cable? You can get long cheap cables from a large online store that feature singing boxes in their adverts (which doesn’t freak me out at all...) and ships worldwide.
