Found a Bargain? Do Tell.
Arrived today and came with the plastic platforms that mean you can use them as non-clipless if required (as well as the cleats). At £13.49 worth buying and putting in the garage for use at some future point!
Mine have the plastic platforms too which I so don't want (swapping from A600 as I want double-sided)...how does the plastic platform come off (I have had these before and never managed to remove)!
winjim
Use a screwdriver to lever open the springy bit of the pedal. It may require some force but they should then just pop out.
London
Mine turned up today, thanks also for the spot - heavy beast, 1.42kg excluding extension cable - should I really be having doubts on the strength of the mounting bracket to hold it.
yes mine came as well.
toeknee
Wirral
Also In
Details
The Clubman series, fleece lined, Roubaix bib tights, are a must have for any cyclists wardrobe.
This super versatile bib tight is the perfect solution for riding all year round.The soft, fleece lining keeps you warm in cold weather, without restricting movement and comfort in the riding position.
The high stretch Roubaix fabric and pad-less seat area allow you to wear these Clubman tights both on there own, or over the top of padded cycling shorts.
  • Fleece lined Roubaix main body fabric
  • Anti friction flatlock seams, for added comfort and durability
  • Pre shaped anatomic fit, for added comfort during the pedaling motion
  • Extra high and wide bibs for added warmth. Lockdown front zip for extra adjustability
  • Foot stirrups for added comfort and superior fit
Additional Information
Product Code:CLPXCRWT
Planet X Clubman Roubaix Winter Tights CLPXCRWT
11 Reviews
Versatile, fleece lined, bib tight. The perfect solution for cold weather riding, from autumn to spring Full Description
From£14.99Was £29.99 50% OFF
Size Select 3XLargeLarge
Colour Select Black
View all availability
Add to Basket
On-One Merino Seamless Arm Warmers£3.99Was £14.99
73% OFF
On-One Thicky Merino Socks (3 Pack)£5.99Was £9.99
40% OFF
Planet X Aquapro Rain Gilet£34.99
Planet X Thicky Merino Socks (3 Pack)£5.99Was £9.99
40% OFF
Planet X Windproof Headband£3.99
Super Summer Clothing Bundle£59.99Was £102.94
41% OFF
