I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
but the rear mech is different to the old one so the chain lengths don't match.
[Edited by @I Like Skol to correct errors]
I recently fitted a new Shimano 105 med rear mech and chain. Not able to use the old chain as it was from the small mech . Always measure chains by wrapping the chain round big cog at the rear and outer ring at the front, plus 2 links (one if you are using a master link).
The chain length shouldn't alter if the mech is swapped from short cage to med/long cage using this system, although in practice you might want to run a slightly longer chain with the longer cage mechs to allow the mech to run at a more optimal position, but this will depend on how much wrap/slack you require the mech to take up.Take the shortest length that will just reach, and then shorten that - I think NOT! (Something would snap if, nay, when you get distracted and accidentally select big-to-big.)
Do that PLUS an extra inner/outer link pair.
