We all learn by making mistakes, at least it got caught early and no damage done.It was, I didn’t see it, I shouldn’t be allowed anywhere near bicycles, no aptitude for it all.
Pity that, I have quite a perverse affinity for damage photos.We all learn by making mistakes, at least it got caught early and no damage done.
And it looks like you have mis-routed the chain around the rear mech cage as shown below
The chain should thread through above the tab.![]()
I give up!
Yep, looks fine, keep riding...….
Indeed, it's not my first time fitting a chain, but the rear mech is different to the old one so the chain lengths don't match.
mistakes exist so we can learn from them , you are not the first to route a chain like that and you wont be the last![]()
Misrouting the chain is my party trick.![]()
I’ve just remembered I’ve got ‘previous’ for doing this, I rode my Hybrid for ages with the chain on the wrong side of that lug, discovered by accident. You’d think I’d learn.I recently fitted a new Shimano 105 med rear mech And chain .Not able the old chain as it was from the small mech Always measure chains by wrapping the chain round big cog at the rear and outer ring at the front.Minus 2 links (one if you are using a master link.Threaded the chain and had the same problem as you.After much head scratching I realised threaded the chain over one of the guides.
Be patient... Once people take pawl's advice, you should have plenty of damage to enjoy!Pity that, I have quite a perverse affinity for damage photos.
Take the shortest length that will just reach, and then shorten that - I think NOT! (Something would snap if, nay, when you get distracted and accidentally select big-to-big.)Always measure chains by wrapping the chain round big cog at the rear and outer ring at the front.Minus 2 links (one if you are using a master link.
