youngoldbloke
The 'R' lined up with the valve gives you the reference point - you've done fine - it was Eddy's post I was responding to. (I run Gatorskins at 100psi front, 110psi back).I will not!
I like the logo more or less equidistant. Depending on how resilient they are hopefully I won't be needing to change tubes often.
Can't you tell that by using a long valve tube & being just off the R in "Gatorskin" in reality I'm not too bothered about the aesthetics.
Good laugh on this thread though. Still not sure if inflated right though - any guides?
