Gravity Aided
- Land of Lincoln
Cut down your salt intake, and exercise. I suggest riding a bicycle.My maximum heart rate is around 180/190. However, when I read this thread it only went from 50 to 70. What should I do?
Holy PSI debate Batman!
As I read it, the OP understands that the number on the sidewall is the maximum to which you should go. Nowt wrong with that, so surely going into the technicalities of ideal pressure really isn't an issue?
All he wants is for his wheels to look good.
Generally run my tyres NEAR the max PSI and has worked for me in regards to not getting punctures which is my main consideration - NOT comfort.
In 2 years and quite a few thousand miles I have had a slow cut puncture, a pinch flat & a tyre split down the seams after under 50 miles - that was a Schwalbe Blizzard - manufacturing defect.
As far as I am concerned none of them were anything to do with incorrectly pumping the tyres up! Amusing anyhow...
leave it go dusty - this thread was never about tyre pressures in the first placeSo you say your tyre pressures work in terms of you not getting punctures - and then you go on to say that you have had three in the last two years? By comparison, in the same time frame, I have had zero punctures - through running my tires at the correct pressure![]()
No it wasn't. And he said he understood that the PSI number was a maximum tolerance rather than a recommendation in his second post. For reasons that I really don't understand, you decided to bang out about recommended tyre pressure...
Usually I just fit em so that the recommended PSI is next to the valve as I am too lazy to have to look for it.
I run various different sizes & manufacturers whose max PSI differs. Usually the max PSI is hidden or hard to see / find therefore I put that info next to the valve so I don't need to search for it.
I can then quickly adjust the gauge on the track pump to ensure I don't go over the max
Why is it not good practice to read the max PSI recommendation, adjust the gauge to the max and then pump the tyre to within those tolerances?
You said:
The PSI figure printed on the tyre is usually the maximum safe tolerance, not really a recommendation for how much air to put in.
He responded:
Yes realise this about the PSI
they're talking bollocks. a decent track pump should do up to 140psi if the tyre can take it (and the valve isn't too shiny).Hi guys. I'm a member of a few forums but this is my first post on this one so be gentle with me. First off I've enjoyed the banter on this post. Rather than start a new thread I thought I'd ask a question which is related to this subject.
I've just bought a Boardman Team Carbon road bike with 700 x 23c tyres fitted with a max psi of 120 printed on the side wall. Now I'm about 65kg (10.5 stone) and do recreational road riding in local country roads in Worcester. I was told by Halfords (who I was very impressed with before we get into that one) to use 110psi but when I complained that the pump I bought a pump off them blew the presto valve off at 80psi they told me that "they all do that and 80 psi is what I should be using". I thought it was 110psi?? So for the type of riding I do what Psi would you recommend. Cheers all.
