mrmacmusic
- Tillicoultry
OK so I'm over-analysing again, but looking at shoes it would seem that the non-waterproof Shimano MT42 (£55) + overshoes would cost roughly the same as the waterproof (GoreTex) Shimano MT60 (£80).....
Aren't bikes supposed to have bells and such as well?
They look interesting, particularly as they can also be used with normal shoes.... hadn't thought that might be worth considering, as I'm sure at some point I'll take the bike on holiday to Center Parcs. Thanks![]()
These are the pedals that I've got on my commuter, and I really like the option of being able to just jump on wearing trainers. In reality I only use it without my proper shoes 5% of the time, if that, but for me it's worth it.
I see that you have already made your purchase, so the advice above is too late!
Hi there,
Know you've had lots of advice ind ideas etc but just wanted to add that I love M520's. Have had them on my last two bikes and can't recommend them enough! Really easy to clean and maintain (as in I've never really had to do anything to them apart from the occasional blast with WD40!). If you get chance can you let me know what the Planet X gear is like when it comes through?...I'm very tempted!!!
p.s. When I fitted my pedals on both bikes had to adjust the seat height to compensate...just a thought if the ride position feels a bit weird when you first try them![]()
Size larger with Shimano's seems to be the rule of thumb. I'm usually a size 10 and I've ordered a size 45, so hopefully they'll be fine – I tried a 46 on in-store but they were too big, the 44 was too tight, and there was no 45 in stock predictably enough!
I went for Shimano MT42 (£55 here) simply because I preferred the styling... pretty sure those M063's would be fine![]()
