Marie Attoinette Fan
+1 thats what I used the last time. I've lost my proper cycling cable cutters with a built in crimper and used a cheap cable cutter from ASDA (£2.99 iirc) and electrical pliers I had to hand.I use electrical pliers![]()
I had a high quality pair of cutters that were not cycling specific, but then worked out that they don't work on gear cable outers, as they splay apart. So down to the LBS and I have the Park ones http://www.google.co.uk/products/catalog?q=park cable cutters&hl=en&client=firefox-a&hs=jzU&rls=org.mozilla:en-USfficial&prmd=imvns&resnum=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1024&bih=579&um=1&ie=UTF-8&tbm=shop&cid=4522240013884429132&sa=X&ei=RdCaT4nkFoO50QXR7a2ODw&ved=0CG8Q8gIwAA - stunning bit of kit
if that's how you use pliers... i cant see you getting on any better with a more expensive toolYou sound much more dexterous than I am: there would be ferrules flying off at all angles, swiftly followed by little pieces of my fingers.
... The biggest faff in finishing off the ends of cables is getting the wee ferules IMHO. I don't reckon I/hope I don't need a box of 500 ....![]()
This generally doesn't work.
The ordinary solder that you'd just have around doesn't stick to stainless gear/brake cables
I use shrink sleeving and fit using a Heat gun or Hair-dryer. This method is tidy, does not flatten or splay out the threads of the inner cable so that it can be re-threaded through the outer for maintainance.
