Scilly Suffolk
Before I part with my hard earned, I just wanted to confirm that this is what I want to finish off the ends of my cables.
Thanks in advance.
Thanks in advance.
A good idea, but as I'd have to buy a soldering iron and I'd still need a pair of cutters, which will have a built-in crimper, I think I'll stick with ferrules.You can run a small amount of solder into the end of the cable to prevent fraying, this also means you can remove cables without having to remove or replace ferrules.
A proper cable cutter from the likes of Shimano will have a built in crimper, usually between the handles.
Applying glue before cutting sounds like a good tip: thanks.Or easier is a thin coat of Superglue to stop fraying (Tip: Coating the area to be cut with Superglue makes for a better cut too) - and a pair of regular pliers will crimp ferrules ... no need for special tools.
Rob
That reminds me of a video I saw of a guy using a jet engine to barbecue a whole cow in about five seconds flat.I have been known to occasionally zap the ends of cable inners with a welder to stop the ends fraying...
