swee said:
Just an aside... you have purchased gear cable as opposed to brake cable?
They are not supposed to be interchangeable.
They are gear cables, I believe brake cables are thicker but I'm probably wrong
palinurus said:
Does it only happen under load or does it shift down even when you've got it on the workstand/ hung from a tree or however you do it?
Originally it did both, which I thought (and still think) was down to a dodgy cassette.
This time it's doing it in the stand, I haven't road tested it yet as I don't want to risk damaging the new cassette with the chain keep jumping to and fro
MartinC said:
Amongst all the other causes this can be triggered by the cable binding in the guide under the BB - frame flexing can then tug the cable. Clean and lubricate to fix.
There's no dirt under there at all, it's been thoroughly cleaned and it's a new cable.
Thanks for the ideas all, I'll post back if the new cable fixes it or whatever the LBS comes up with.
