EV Owners Thread
Tenkaykev
Poole
"Using a typical 7kW charger at home the charge time is 9 hours and a half hours. Charging using a 11kW charger however reduces this time down to just 6 hours 15. This is a large contrast to using the 3-pin charger which comes with the vehicle on purchase, this can take up to 35 hours to charge from 0% to 100%"
Couldn't see one in the boot, I'll check again 👍
BoldonLad
Not part of the Elite
South Tyneside
A question for this sub forum We're currently at our daughters place in Leeds. She has a VW id3 and a dedicated charger on her wall. When she visits us for Christmas I wondered if there was any way that she could trickle charge from our domestic supply? I looked in the boot and there's a length of yellow cable with a dedicated plug on either end. I know there's several local charging stations but wondered if there was another option. We're having solar PV installed next week, and see there's an option for a dedicated car charging station, but as we no longer have a car it seems like an expensive option for irregular usage.
Not an expert, but, I think the short answer is "yes". ie, it is possible to charge from a "normal" 3 pin plug, it just takes much longer (and, may cost more), but, if her car is going to be parked at yours for the duration of the Christmas festivities then, charge time may not be an issue
Yes you can. We've done the same with our Leaf several times all over the country.
Obviously it takes longer but you can do it at home. Get an approved extension cord if the socket isn't nearby.
CXRAndy
Lincs
My best trickle charge was when I dropped my 75ft extension cable out of 2nd floor French chateau window to charge my car.
It dribbled 7 miles per hour, but was more of an experiment rather than gaining necessary charge :biggrin:
icowden
icowden
Surrey
The good news is - yes! There is!
She just needs a "granny" charger cable with a normal 3 pin plug on the end.
The bad news is that VW do not supply these cables as standard. The good news is that you can buy them. The further bad news is that they are not cheap.
They cost in the region of £100 depending on how long you want the cable. They can not be connected to the regular cable to extend it further.
Obviously charge rate is slow, about 3 miles for every hour plugged in.
CXRAndy
Lincs
Buy the 16A rated extension cable. The max power supplied is 3kW, safe enough for 3 pin plug with 13A fuse
albion
Gateshead
Unless the battery packs are pre heated for charging it would be best to stick to 3KW charging if you can, especially in winter.
icowden
icowden
Surrey
Not sure about that. 15C to 35C is said to be the ideal operating temperature, and I would assume the same for charging.
A lot of assumptions there. Cold weather does mean that it can take longer to charge and that range drops. However it doesn't damage the battery. It would if the battery was not designed to mitigate the damage however, Lithium plating can happen when temperatures are low. The majority of EVs have battery management which heats the battery so that plating doesn't happen.
Additionally, if you live somewhere cold, you can usually pay for a heat pump as an add on which improves both your range and your charging.
