- Somewhere wet & hilly in NW England.
What's the break-even time period on an average solar install these days?
its not easy to work out unless we know current kwh usage, size of system you required, selling back to the grid, battery storage etc etc….What's the break-even time period on an average solar install these days?
what i do know, is right now they are getting pricey to install and long wait times.
Mine was easy to calculate - just add up the FIT payments until they exceed the purchase cost - so less than 6 years. Probably less than that if I include the reduction in my electric bills, which I didn't.
But theres no fit payments anymore…….
Yes, I know that, but the original question was 'how long is the payback'.
Which is harder to work out with no fit payments, very low grid export rates and variable size systems and usage…..
Yes, agreed.
I guess one way, would be to cost out your reduction in usage based on average for (say) the last 5 years, and add on the amounts you do get for grid export.
FIT was easy, they pay (63p /kwh) regardless of whether I export it or use it myself. This year over £2700 in payments, so pay back would be quick. Guess that's why they stopped FITs.
Seven days.Your foggy week lasts how long ??
Yes, and you appear to have answered "how long was the payback?" which is interesting but different.Yes, I know that, but the original question was 'how long is the payback'.
Radiators generally bigger but some needed replacement anyway. Pipework only what was needed to connect the pump outside instead of a boiler inside (but the old boiler position could not be used for a new one either: the old one was melting the neighbours' gutter!) and remove the open loft tanks from the system. No underfloor (but possible in future) and insulation was already good. No mains gas here, and a heat pump beats an oil boiler hollow.It's good to hear from someone who's actually used one for a while. 300% would just about put the running cost on a par with an A-rated gas boiler. How much did you need to do in terms of bigger rads, pipework, underfloor heating or insulation?
Indeed. You can also get gas boilers with variable flow temperature and weather compensation control, which would be more efficient than how most are used now... but one day, electric prices will be unlinked from gas and, as someone pointed out earlier, we're not likely to make gas domestically any time soon, but home electric generation will just keep improving.StrIctly speaking, the often-quoted requirement for extra insulation is a cheat because you'd get the benefit with any heating system.
