As we face the probability if boiler replacement in the next few years (its over 25 years old) air source heat pumps are definately OFF the consideration list for several reasons .
We are fresh air lovers, its 6c outside, its been 9c generally today but our heating hasnt been on at all today , windows have been open as well. When we do heat the house, it starts from very cold (maybe 14 or 15c inside) air source has no chance in those circumstances.
Presumably even the gas boiler costs a bomb to heat it up from 14? But indeed, an air source heat pump with 40ish degree radiators will take longer to heat it up than a gas boiler with 70ish degree ones, and I understand the current air source heat pumps with high-temperature radiators cost more to run than gas.
No way can i live in an airless stuffy, windows closed house.
So change the air in it. Heat-recovery ventilators are available. And if you want a breeze, then go outside and leave the house warm for later.
My son (gas engineer) has studied them a fair but. A very very well insulated house is a pre requisite.
Only a pre-requisite if you want the grants. May I suggest that gas engineers have a tiny bit of a conflict of interest?
we fail because we like fresh air. Supplementary heating (underfloor or similar) may well be needed?
It sounds like you fail because you open the windows and then heat a cold house quickly. Not sure what difference supplementary or underfloor heating would make: if you open the windows, it'll still get cold and cost lots to reheat quickly.
Supplementary water heating may well be needed. As a bath lover, it would be a neccessity.
It's usually installed (just like most fossil-heated tanks have an immersion for emergencies), but unless you have your baths hotter than 55°c (hot enough to cause third-degree burns in 30 seconds or less: the NHS recommends 46°c max), it wouldn't be used except for occasional legionnaires-killing and when outside temperature falls below -10°c for a prolonged period of time. If you have solar PV or solar thermal, you might choose to have supplementary water heating to save money.
Unless you hyper spec the system, with all the cost involved, its simply not going to work for people like us....and perhaps many others
It might, or it might not, but if all the above myths and legends were true, it wouldn't work for anyone, definitely not somewhere between 15 and 40 million and increasing across Europe. There's so many installed in Norway that oil heating was banned in 2020... but the UK lags behind most of Europe, with fewer than 10% of France's heat pumps, with these odd zombie myths stumbling onwards.
