Emergency help! Brakes again.
Glasgow
As I understand it, yes, and that is why the advice to loosen the nut as given above, only applies to road caliper brakes where there is one bolt in the fork crown.
Oh, sorry, I understood the nut that tightens the brake cable on v-brakes was meant.
Hope Sara has sorted it, I remember it took me hours to figure it out, all the you tube videos were mentioning just the springs, never the cable.
Cyclist33
Warrington
Hope so too. V Brakes have a lot of potential adjustments if they get knocked out of place! I took mine apart. The spring on one of the arms was bent, it had a dogleg so this was throwing everything else off. I had to beat it straight. There are also little washers behind the arms, where they are bolted to the fork, which change the default brake arm position depending how you position them, because they connect to the spring mechanism.
mcshroom
Bionic Subsonic
Also check the brake pad is making contact with the flat surface of the wheel and not missing too low. If a bit of pad is below the rim then it can cause a lip to form on the pad which holds it against the wheel.
Sara_H
Sara_H
Unfortunately can't get it sorted. The arm isn't moving at all no matter what I do.
Not sorted! Given up now as bed will be calling shortly and I've lots of other stuff to sort out before bed. Will have to make other arrangements, no way I can ride the bike - was planning to do a bike/car swap as OH is on nights so will be coming home when I get there (we work at the same place) so will have to give it a miss.
Scoosh
Velocouchiste
Edinburgh
Both sides are connected, aren't they ? ie - you haven't released the cable when changing a tyre and omitted to replace the noodle in the the wee locking thingy, have you ? :whistle:
Glasgow
You could try riding with only the back brake until you get it sorted, if the trip is really necessary.
Sara_H
Sara_H
:laugh: Yes its in. I think it'l have to wait til the weekend now and Ill take it all to bits and start from scratch.
It's not too much hassle. It was more for OH's benefit, he's just started doing nights again after a couple of years off them and was dreading having to ride up the hill in the Morning, so I was going to drive part way, then ride part way let him ride back and take the car up the hill.
Roadrider48
Voice of the people
Londonistan
Doesn't cut it if v-brakes, as each one is bolted to one of the fork's tines.
Absolutely!
Sheffield_Tiger
Sometimes, cheaper vees just go that way in my experience...not sure why, perhaps they make the springs out of those processed cheeztrings things
A mate's Spesh sirrus just kept doing the same no matter what I tried, including removing the brake arms, cleaning the pivots and changing the location point of the spring on the bosses - ended up rummaging in my parts drawer for a spare set of vees I had, as it became clear that they weren't going to play ball.
...although if you REALLY want a brake setup challenge I have the nightmare combo of a Tektro power hanger and Suntour SE cantis in said parts drawre
