Is that enough to keep the chain lubricated?GT85 on a rag and run the chain through it.
Do it before each ride. Takes a minute and keeps the chain clean.
You can use wet lube bit it'll stay wet and dirty.
If you are rigorous about cleaning your chain you'll get away with dry all through summer and most of winter (depending where you live). I'm less rigorous though (except in winter when I am rigorous) and use Finishline Ceramic Wet Lube. In summer I can leave that a few weeks no problem and wipe it off revealing a clean chain. Other wet lubes take a bit more work and attract muck.Cant work out which to go for!
Road bike I plan to just go out in dry weather - in winter this could be damp, with spray on roads but not when raining.
Hybrid - As above aside from those times when i go out and i get an unexpected shower!
I really need one 'in between' - but which of the 2 is best to use based on above? Leaning towards wet?
Yep I’m using ceramic , cleans easy , however in depths of winter the green wet lube stuff goes on!If you are rigorous about cleaning your chain you'll get away with dry all through summer and most of winter (depending where you live). I'm less rigorous though (except in winter when I am rigorous) and use Finishline Ceramic Wet Lube. In summer I can leave that a few weeks no problem and wipe it off revealing a clean chain. Other wet lubes take a bit more work and attract muck.
I still used it (Finish line wet lube) when I lived in Fife but it was cleaned straight after a ride or at worst the next day but it always lasted/ protected nicely and wasn't too much extra work. I used Muc Off Ceramic Wet lube last winter when I was back in Fife, it was sh1te. Wouldn't even last a ride and if you didn't clean the chain within 20 mins of getting back from a ride (before you've even had a chance to eat/ recover) it was a night mareYep I’m using ceramic , cleans easy , however in depths of winter the green wet lube stuff goes on!
