John the Canuck
..a long way from somewhere called Home..
- Strathaven, Lanarkshire
bought a tin of Dry Lube with Telflon
ok cleaned chain till rags quite clean - not de-greased just wiped
no instructions with Dry-Lube - so added 1 large drop across each roller
then slowly run gears up/down for 2mins
considering this is my ''best bike'' = ie. dry weather only and no Muc-Off type cleaning
how often do you re-apply the Dry-Lube..?
thanks.....john
thanks.....john
