ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
That's why my LBS used a piece of scaffold pipebonj said:no, it was metal but quite thin metal.
!That's why my LBS used a piece of scaffold pipebonj said:no, it was metal but quite thin metal.
!bonj said:nah sod it. new cranks it is.
I might try mickle's method of disassembling the pedal and putting it in a vice and taking a heavy pipe to it (I did try it with a piece of hoover pipe and a metre-and-a-half-long broom but they showed signs of being weaker than the interface i was trying to undo - especially on the crank arm's current movable state) - there is a vice in the garage, but it's not attached to anything. I might try and attach it to something and remove the pedal just to satisfy myself that it can be done and to have a spare pair of cranks but I've ordered everything i need to change the BB and cranks and the sprocket i've ordered (19t) is going to be a bit spinny with a 46er, will probably be under 65" whereas with a 48 it'll be 66.7".
Steve Austin said:Have you considered launching a piece of moon rock from a trebuchet aimed at the pedal spindle??
Dannyg said:Last year my pedals got stuck so fast that I couldn't remove them however much force I applied.
However I took my bike into my LBS and they were able to free them up, largely because they seemed to have industrial size pedal spanners which they could apply a lot more force with. It still took a lot of swearing as well.
So you might want to see if your LBS can help before you fork out on new cranks.
jayce said:after fixing apply a small amount of copper slip its anti seizing
That may have been the case but since the plating material is reluctant to attach itself to inside surfaces I'm not sure how much of a factor it is/was. If you are electro plating a crank shaped object for example the inside surfaces of the object are in proximity to and therefore have access to fewer saturated molecules per cm2 than the outside surfaces. This combined with the way that the electrical current flows around such a shape can result in the external surfaces receiving plenty of plating whilst the inside receives none at all. Its the reason that chromed frames always rust in the area between the stays nearest the bottom bracket.tyred said:Old cranks were usually chrome plated after the threads were cut making the threads very tight even when they were new.
mickle said:The best option though would be to soak it in penetrating fluid overnight, dismantle the pedal, whack the axle in a vice and stick a length of pipe over the crank. Easy.
gbb said:Can you get the pedal off the axle, then apply some heat to the axle. The expansion of the steel can often aid removal.
mickle said:That may have been the case but since the plating material is reluctant to attach itself to inside surfaces I'm not sure how much of a factor it is/was. If you are electro plating a crank shaped object for example the inside surfaces of the object are in proximity to and therefore have access to fewer saturated molecules per cm2 than the outside surfaces. This combined with the way that the electrical current flows around such a shape can result in the external surfaces receiving plenty of plating whilst the inside receives none at all. Its the reason that chromed frames always rust in the area between the stays nearest the bottom bracket.
