MacB
- Farnborough, Hampshire
Yup...and you can just make your brain hurt trying to work all these things out!! The combinations people can achieve through chainring/cassette sizing are bad enough, let alone with hub gears (be they Alfine/Rohloff 7-14 speeds or SRAM DD-type triple replacements) thrown in. There's no such thing as a 'one size fits all suits all riders all the time' gear system, nor is there likely to be!
I just take issue with any suggestion that I was led into the choices I made through marketing etc. I like Campag shifting. I considered the reasoning behind 11 speed and it stood up. I knew a compact suited me and the bike just nicely. Athena had excellent reviews, and a friend of mine had 11 speed Record. Hence, I went for Athena. It works for me. Deal with it....
??? deal with what, you can run whatever you like, no-one cares, what they do care about is the information given out around doubles, compacts, triples, etc and how much the 'industry' caters to customer needs or marketing tries to lead the customer to what is easiest/most profitable for the manufacturers. Or are you going to try to tell me that there is no macho factor around the use of 'proper' road doubles, over compacts and over triples, in that order? I mean, even the term 'granny ring' says a lot.
But as all round cycling advice goes - this works for me, a compact is a good choice, yes I have to get off and walk sometimes but I'm ok with that - it's hardly ringing endorsement territory
