chonkers
- newcastle upon tyne
yea addictfreak avid juicy 3 disc brakes stopped u on a sixpence lol
cheers
ian
cheers
ian
chonkers said:to be honest dont think it is set up right its from halfords and lad wasnt much help when on seat i struggled reaching brakes on drops ive since lowered seat and moved it forward and find it helps a bit also when of the saddle feet on ground there is no clearance now i thought at time a would of been suited to a med size frame as only 5.7 he said i needed large frame i will get used to it i guess just never had a road bike since aged 14 and marinyork your right there mate pulling away etc and when peddling i noticed how much faster it was and found i was always reaching for brakes.
cheers
ian
Sheffield_Tiger said:Or just twist the bars slightly upwards - doesn't need a vast amount of movement - that's what I did on the Virtuoso after finding the levers just a tadge on the low side and awkward to ride on the hoods.
Doing that on my bike as a temporary measure, I've never felt the need to move the bars back and alter the lever position. Maybe when the bars are due for new tape...
Or turn them upside down 1980 10-speed stylee!![]()
ttcycle said:not best to tilt too much as they should be straight. Tiger are you sure the rest if the set up is right?.
Sheffield_Tiger said:For me, on the M, it only needed a small tilt to make a noticeable difference.
addictfreak said:Does your Rockhopper have disc brakes? If so you will notice a vast difference between the two.
marinyork said:When did you buy it? I wouldn't rule that out yet? I'd work from the principle that if the bike is the wrong size it's better to get one closer matching to you than trying to buy adjustments for it - a friend has this exact problem and he's ended up not using the bike.
PK99 said:disc brakes on an mtb stop the bike
rim brakes on a road bike slow the bike - sometimes in the wet only marginally!
