bonzobanana
Maybe I am a bit German here but I do not consider this a valid statement and am also wondering on what foundation you think that hub Motors for a Brompton are not that "powerful". The Brompton fork is not designed to take any torque at all as on a human powered Brompton you would not have torque on the fork. You have a huge range of different motors from Crystalite direct drives to geared motors like the Tonxin models, that are used in most retrofit kits today. They do have a nominal power of "just" 200-250 Watts but can vastly go beyond that in certain situations. The amount of torque they produce is most of the time not even layed out in the datasheets of the motors.
Steel forks on the other hand are vastly different, too: From a massive fork of a BMX bike or a cargo bike over slim elegant models on Racebikes to cheaply build forks on bikes from a hardware store. There are dozends of different steels, each with their individual properties. There are well crafted and badly crafted forks. There are different fork designs. Just because the fork ist made of steel this means exactly nothing.
Do you have any experience with a retrofitted motor in a Brompton? Are you an engineer with experience in bicycle fork design and specification? Most retrofit motors just use the existing dropout to keep the motor's momentum unter control - clearly nothing that the Brompton dropouts were designed for. There is a reason why torque arms exist: https://ebikes.ca/product-info/grin-products/torque-arms.html
And on the other hand there is a reason why forks for disc brakes are stronger and differently designed from forks for rim brakes. There is way more to consider than just the dropouts as forces from a motor (or a disc brake) onto the fork are obviously completely different from no forces onto the fork...
So generalisations do not work here, neither with motors nor with forks. There are a lot of bikes with steel forks where I never ever would fit a motor.
Practice seems not to have shown massive issues - still this is a bet because probably no one ever really checked the Brompton forks regarding the use of a motor from a solid engineer's perspective including tests, measurements and reviewing desingns and materials. Apart from Brompton themselves - and they changed the design of their fork for the electric version. As this rises cost this says something: They probably wouldn't have done it w/o a reason. So it is probably a valid assumption that current retrofit motors typically do not overload the fork under normal circumstances (that's what the practice shows but no one takes warranties for that) but that on the other hand the fork is probably used beyond it's spec, technically within the stretched safety zone buffer and this seemed not to be safe enough for Brompton themselves (thus they designed a stronger fork for their Electric).
There are definitely steel forks I wouldn't want to use with a hub motor but my point was more about the material steel being more dense and being better to deal with the torque of a hub motor on the dropouts especially a small geared hub motor which might only produce up to 45Nm or less and be relatively low speed. People fit 2000w hub motors to the dropouts of aluminium frames which are much softer, often they have to fit torque arms to prevent the dropouts getting chewed up. It's pretty much always easier to fit ebike kits to steel frames and forks where as aluminium and carbon fibre need much more consideration and sometimes reinforcing.
Lets not forget that having a front hub motor means going up hills is now a 2 drive system with the driving force shared between two wheels. This can reduce the flexing in the frame itself as the rider doesn't have to work so hard. There are positives to a hub motor on the fatigue on the frame itself its not all negative. Sharing the driving power between the two wheels can be a positive thing.
I understand your points and I accept many of them but I guess my point is in the scheme of things steel frames and forks typically are much easier to fit ebike kits too safely compared to other materials.
The cheapest nastiest ebike I know which before pandemic pricing was sold at £299 is the Assist ebike at Halfords. It has quite thin high tensile steel forks that are nothing special and a front hub motor and the bike has a total load capacity of 160kg including bike weight, luggage etc. The forks don't appear to be any different to the forks fitted to the same frame when it has a hinge fitted in the middle and sold as a basic non electric folding bike. I think the spoke count has increased to 36 spokes though.
Lots of people who fit ebike kits to steel frames and forks don't even bother with torque arms even when fitting very high wattage hub motors that produce torque between 100-200Nm.
It is impossible that a brand new ebike for GBP 299 ist anything else but trash from factory. Even a non-ebike for that price would have to make a lot of compromises and for the money you would have a hard time finding a motor kit alone that works (and you won't be able to find one that has at least acceptable quality).
) and many of the competing companies suffered from reliability problems - namely BionX ruled themselves out of the market this way, starting from a market leader position. Today, apart from Bosch there is a massive share in mid motors from Shimano as well and outside Europe apart from the Chinese Yamaha is dominant, they even sell their own bikes (and announced only a couple of weeks ago that they now want to seriously start conquering the European market). Bafang produces all sorts of motors and is trying to gain traction in the higher level markets, coming from the budget low end bit of the market. So I'd say the situation is way more complex than your analysis suggests.
Apart from the fact that in forums basically everything is debatable, even facts. Including the question wether the facts are actually facts. That's one of the main reasons why forums exist and what causes the traffic in forums.
