Dogtrousers
Kilometre nibbler
A person from RWGPS actually came on the forum some time ago and explained how it works with multiple maps. I'll see if I can find the post.
I purchased my first Garmin 1040 bike sat nav last year. Because it works in partnership with Ride with gps I also purchased the app as well at a cost of £70.99. I’ve downloaded a few courses that others posted up. It seems very expensive for what I’m getting out of it. Maybe I didn’t need to purchase it in the beginning 🤷♂️
All I’m after is some local rides that others recommend and try them out myself at the weekends. I know I can download directions with the Garmin app but not recommended rides as such. At least I can’t find them🤷♂️
What’s your thoughts please ?
What's with this new GPS thingy....
I use those signposty / mike stone markers...
much more hi-tec!
Coats, gloves leaves....! 🤣🤣🤣
Similar happened on my ride this morning, it tried to get me to cross a major road to use an “alley way”.
I gave up trying to create my own ride as it kept putting me on the footpaths it calls alleyways.
My GLW uses RWGPS for route planning, but always uses it in Driving mode, otherwise it will tends to default to sending you down trails/bridleways etc.that it thinks are suitable for bikes. If you ride a road bike then driving mode may be better?
much more hi-tec!
I set it cycling mode otherwise it puts me on freeways or major busy roads. You have to review the route either way. I wish there was a road bike mode, but they can only use the data Google provides. Use street level or, lacking that, satellite.
She checks new roads with Street view, but we now both tend to use komoot, especially on holidayin new areas as the mobile version means we don't need to take a laptop with us
No really as it has an indicator to tell you if a road is unpaved. Maybe tell the GLW she's doing it wrong....and then make yourself scarce for a while
It may have an indicator to tell you the road is unpaved, but that doesn't stop it trying to send you down it.
You have tio check the proposed route for unpaved sections, then add waypoints to force it to go some other way for those bit. Perfectly doable, but fiddly.
