BentMikey
Rider of Seolferwulf
- South London
Smokin Joe said:That's an improvement.
Three pages before someone trotted that old myth out again.
+1
Riding fixed tells you that it's bollocks.
Agreed.BentMikey said:+1
Randochap said:Disclaimer: It's impossible for anyone else to tell you exactly what your gearing needs are, or what gear you need to personally conquer a given incline.
However, beware of advice from people who say: I have a 39 X 26 and it gets me up anything. That's their experience; not yours.
Also beware those who say a compact double with the same ratios is the same thing as a triple. It's not.
This has been discussed endlessly, but here we go again:
A triple, over the same ratio spread has the advantage of closer spacing. This means that when you bail out of the big ring, on, say, a 50-40-30 triple, the drop is only 10 teeth, rather than the 16T drop from 50 to 34 on a compact double. Smaller difference (and 10 teeth is perfect IMHP) means you don't lose your cadence and end up spinning like hamster on a treadmill.
Mostly, I'm using the middle and big ring on the triple. Granny gets lonely, but is always there on a long ride, when an 18% grade pops up. In fact, when a very steep hill presents anywhere, I'm likely to spin
But, as I said, I have no idea what your needs are.
punkypossum said:Right, thanks for all the feedback! I think I'll better stick with the original triple plan...just seems to limit the choice of bikes considerable....![]()
I assume you are looking at the 2009 Allez 27, as this has a Tiagra rear mech but note not front as that is Sora, along with the STI levers.punkypossum said:Which is apparently quite substantial...
Lets say I went for something like the Allez, with sora shifter but tiagra mechs, would it be possible to just change the shifters to tiagra if I don't get on with them or is that going to be ridiculously expensive as well?
I just don't want to rule out potential bikes if changes are feasible and don't end up doubling the price of the bike...
