Landslide
Rare Migrant
- Called to the bar
punkypossum said:...was informed by the grumpy sales assistant thatonly fat, old, unfit men need a triplehe only had a double in stock, and couldn't be @rsed ordering in a triple...
Gearing is personal.Over The Hill said:Triple all the way.
I even fitted a smaller granny ring to mine!
I cant see any point in not having one.
Mostly I am on the middle ring which gives a nice range for 90% of my cycling. My concern with a double is that the big ring will be too big and the small to small so I will want to keep double changing from big to small and then compensating on the back.
I like my front gears to be basically stepped to be about equal to a couple of back gears so I can go over easily. Double seem to have too big a jump.
I have just recently written a response in another post about gear ratios that I will replicate here that may be if interest.punkypossum said:Reason I'm asking is that I'm still compiling my shortlist of possible contenders that I will hopefully testride this weekend...
The Giant Defy (2.5, i.e with a triple) has been joined by the Specialized Allez, which comes with a triple, but then only with sora shifters... I'd prefer tiagra, but that then leaves me with the allez sport which comes with an 11-25t cassette and 50x34t chainrings...
I know I asked a similar question ages ago, but it is all very confusing...
Would the Allez get me up somewhere like Beacon Fell? If I went for a double and decided later that I did need a triple, how expensive would it be to change?
Will testride pretty much anything I can get my hands on, apart from the two above, but just would prefer to have a rough idea what will work and what won't.... I asked the triple / double question at Buy-a-bike and was informed by the grumpy sales assistant that only fat, old, unfit men need a triple, but I doubt he was a very reliable source looking as if he fit those criteria himself!
Thanks!!!!
That's an improvement.Randochap said:Disclaimer: It's impossible for anyone else to tell you exactly what your gearing needs are, or what gear you need to personally conquer a given incline.
However, beware of advice from people who say: I have a 39 X 26 and it gets me up anything. That's their experience; not yours.
Also beware those who say a compact double with the same ratios is the same thing as a triple. It's not.
This has been discussed endlessly, but here we go again:
A triple, over the same ratio spread has the advantage of closer spacing. This means that when you bail out of the big ring, on, say, a 50-40-30 triple, the drop is only 10 teeth, rather than the 16T drop from 50 to 34 on a compact double. Smaller difference (and 10 teeth is perfect IMHP) means you don't lose your cadence and end up spinning like hamster on a treadmill.
On my long-distance bikes (see VeloWeb), I run 30-40-50 up front and Campagnolo's biggest spread on the rear of 13-29. I also have a bike w/ (Shimano) 24-36-46 X 12-30 for carrying heavier loads.
Mostly, I'm using the middle and big ring on the triple. Granny gets lonely, but is always there on a long ride, when an 18% grade pops up. In fact, when a very steep hill presents anywhere, I'm likely to spin rather than perform knee-destroying heroics.
But, as I said, I have no idea what your needs are.
Randochap said:I'm likely to spin rather than perform knee-destroying heroics.
