mikeymustard
Yes, the Bigfoot sneaks into your garage at night and pulls on them. He also lets down your tyres a bit@Yellow Saddle Are 5 and 7 not true?
No, for the same reason that frames don't go dead or soft.@Yellow Saddle Are 5 and 7 not true?
Chains wear making the gaps bigger, so they seem stretched.@Yellow Saddle Are 5 and 7 not true?
thanks, interesting article
As far as cables are concerned, the initial 'stretch' is probably due to a combo of: spiral bound outer casing compressing and seating itself in the various stops a ferrules, plus pads and nipples bedding in; later 'stretch' is due to wearing of all components
Some outers are not a tight spiral inside, but have some gaps, so all the cable needs to do is compress the outer's metal into a solid spiral by compressing the plastic. I suspect another common source of "stretch" is cable clamps with insufficiently large grooves that flatten and straighten the inner cable's twist a bit, resulting in what seems like a slight "stretch" the first few times it's pulled to a stop. Both problems seem more common with cheaper parts IME and I expect you'd never sully your bikes with anything less than the best!A spiral bound outer casing will not compress under the conditions applicable to bicycle cables. The tension in cables is too low. The spiral is tightly bound and to get that to go tighter the compression has to take the steel into yield and there is just not enough space between the windings to overshoot the compression enough for that.
So why do indexed gears need so called "compressionless" outers?A spiral bound outer casing will not compress under the conditions applicable to bicycle cables.
I get the picture and have heard that argument brought forward when I used to train people to change cables. That's not what happens because we can calculate the effect with a bit of trigonometry and it is absolutely negligible to plenty of decimals. Outers do however settle in ferrules if they are not correctly seated from the beginning. If you do everything by the book, there is no settlement of cable "stretch" (that hurt to get out) until the cable outer starts to display wear on the inside of curves. Like an oxbow curve in a river that grows to the outside of a curve, a cable inner wears on the inside of the curve through friction and fretting. This causes a relative change of length between the two. It is a relationship change, not a dimensional one in the sense of stretch.I suspect another common source of "stretch" is cable clamps with insufficiently large grooves that flatten and straighten the inner cable's twist a bit, resulting in what seems like a slight "stretch" the first few times it's pulled to a stop. Both problems seem more common with cheaper parts IME and I expect you'd never sully your bikes with anything less than the best!![]()
As for chains, you can keep typing elongating and elongation every time, but most will type "stretch"![]()
No. I'm yet to see a brake cable with gaps in the spiral.
You don't remember shops that used to sell the same slack housing for both, then? Now I feel old...Gear housing is made from steel wire wound in a slack helix whereas true compression proof brake housing is wound from steel ribbon in a tight spiral.
Ok, yeah I agree with you there, in fact I'm told "compressionless" outers can compress catastrophically if you put them on brakes!This is one of those misnomers of velo-speak
I'll pretend that I don't. In those days my cables lasted the lifetime of the bicycle and I didn't know any better.You don't remember shops that used to sell the same slack housing for both, then? Now I feel old...![]()
Even the cable experts call it compression :
"Shift housing resists this flexing by using linear strands of wire that run the length of the housing parallel to the shift cable. These wires experience much lighter
loads, but are designed to keep the housing from compressing, resulting in clean, crisp shifting."
Jagwire's Tech Support Specialist Ben Oliver
http://m.pinkbike.com/news/To-The-Point-Shift-Cables-2013.html
