DIY - Log store
slowmotion
Quite dreadful
lost somewhere
[QUOTE 4931764, member: 45"]I like those. 70x70 timber is easy to get, but 40x60?[/QUOTE]
Loads of timber merchants and DIY sheds do 38mm by 63mm CLS timber. That's the finished sixe, not the nominal one.
twentysix by twentyfive
Clinging on tightly
Over the Hill
Here's mine. About two-thirds of a pallet width is right for the depth of a log store because that's the limit of reach when you are stacking logs at the back then removing them, especially as the pile grows in height and you're reaching under the cover. Also a shallow but tall log store with a wide frontage exposed to sun and wind will dry better than a big cube of damp wood, especially one that's enclosed in a box.
Is that an air brick about to be blocked???????? :stop:
Bonefish Blues
Banging donk
52 Festive Road
[QUOTE 4940853, member: 45"]After the recommendations on here I bought 4 brackets and some wood and built this. The 70x70 is easy to find, but I had to chop down the ends of 3x2 to get them down to 60x40.
View attachment 371219 [/QUOTE]
I haven't bothered to connect the tops of mine and all's still good after 8-9 years of being grossly overloaded!
Globalti
Nope. It's the vent for the woodburner which I put in even though it wasn't required by regs, because I reckoned the cold air would be better coming from beside the stove than under the door, which my draft detector wife would detect. Even when the log store is full the air still flows freely as there are gaps between the logs, innit.
Tin Pot
Tin Pot
I found the pallet I was going to use to construct a store...maybe not then.
irw
Quadricyclist
Liverpool, UK
Do you all actually have log burning paraphernalia? Or is having a log store the secret aristocratic way to avoid posting on the 'too much class' thread, whilst still saying "I'm much classier than you lot!"?
I live in a 'smoke control zone', but maybe I'll build one of these just to be part of the CC 'in' crowd!
Salar
A fish out of water
Gorllewin Cymru
Nice construction. Any idea what those dark coloured logs towards the left are?
I'm no gardener, but I think they are Laburnum logs.
The tree blew down in a storm we had a couple of years ago, landed on the roof, luckily no damage.
I've burned a few of the logs in an enclosed log burner, very slow burn.
Very hard wood, a saw or axe wouldn't touch the main trunk. I had to get someone in with an industrial chain saw to chop up the larger pieces.
raleighnut
Defra approved exempt appliance. :angel:
