@IanSmithCSE
Sorry, it's gone right to the bottom
I took my time, as the first problem was, that the wheel had come set up for a through-axle
I had to YouTube to see how to swap to the provided spacers/axle-ends
Then I thought I'd broke it, as the pawl & spring flew across the room
Once I'd got it the correct way round, so it didn't freewheel in both directions, the disc as screwed on (with thread-lock)
Likewise the new sacrifical hanger was also installed with 't-l'
The cleaned up cassette was fine, as the damaged chain was about a month old!!
The
new derailleur, a short-cage Ultegra
was taken off my unmoved, for about 6 years Ridley...... the furthest it's gone is from a spare bedroom, to the attic!
The tyre & reflectors were moved over, & rather annoyingly, the tyre wouldn't seat straight (high & low spots), so it was liberally showered with talcum powder to help it slide slightly
Which worked.... it smells better too!!
The new chain was one of the two that I bought at
Decathlon, at the end of January
I had to shorten it considerably, as oddly they're 118 links!!
I took out about 8, with going from a long-cage 105, to that (2009) Ultegra
Once the cable was threaded through, it was time for some luck!!
The limit-screws are fine, & I didn't even have to adjust the indexing!!!
One last thing, when it pulled the spoke out, it took the lip off the recess, so it might not have respoked?
