The biggest difference is communication and diversity.
Historically the local development of parallel devices, subtly different and yet with the same function is well documented.
It was impossible to debate or exchange basic ideas due to distance and language.
For instance the people who use canteloupes as bowling balls may not have had access to a greasy burger bar and therefore the secondary role of food was important.
Nowadays though much of the groundwork is already done and available so the need to start at basics or with faith or trial and error is (at least partially) removed. The basic question that is asked now fro most research is what is out there, is it valid and can I add to that information?
If the answer is no then use the work that is already there to inform your choice.... once you have read, critically analysed and decided for ypurself the relevance to your situation - then act upon the INFORMED choice
Scepticism is healthy and should be encouraged. Modern Science relies on this and ranks "evidence" accordingly. NO Scientist in the modern day would expect their results or conculsions to be accepted withut questioning and or analysis. That is the whole point of peer review and critical analysis
Faith is an issue when it becomes "evangelical" and tries to replace Science.
For many years "faith" restricted Science and held back advancement and development..... that is where faith becomes an issue.
Sceince and scepticism examine both sides of the argument and have no problem discussing or debating.
Faith however says my way is right and you should not question it.
