beancounter
- South Beds
PMSL three grand for a Dawes, that's like asking three hundred grand for a Vauxhall....
bc
bc
The OP may not recall your posting about this, but in the interests of balance I should point out that it revolved around you stripping the threads on your stem (which you admited was your fault and not a faulty stem). You then contacted Dawes, who you wanted to buy a replacement from, who told you they used standard A head stems and did not supply parts, only whole bikes.
You then got annnoyed as you were only able to buy a black stem from your LBS rather than the silver one the bike originally came with.
On the other hand one of my rims developed a crack some months after I bought the bike and it was replaced under warranty with no argument.
Chris James said:I would say it is a pretty good buy at that price. Spa Cycles have them at £460, but uisng your LBS is nicer if anything goes wrong
The drive chain is mostly Sora, which is a bit basic but functional. For commuting I would have thought it ideal, as it already has guards, will take a rack, is pretty much bombproof and should feel reasonably sprightly for the weekend rides.
