RecordAceFromNew
Swinging Member
- West London
There are a few possibilities I think.
Presuming the current difficulty is the shift into the largest sprocket, there is a possibility that you are not using the full extent of the stem shifter's travel. If you can shorten the cable (by the clamp/adjuster at the rear mech) by say 3mm, I wonder if the stem shifter will still allow you to hit the smallest as well as the largest sprocket at the back by friction mode if the outer limit screw on the rear mech is loose?.
If the above does not allow both, then there are three possible solutions.
The first is if you don't need all the 8 ratios, and if the cassette allows it just swap the sprockets around so that the 8th is the one you don't need.
The second is if the Huret rear mech's shift ratio is not as high as Shimano's (which is 1.7, i.e. for every 10mm pull at the shifter it traverse the cassette by 17mm), then any Shimano rear mech may give you the full range. I don't know what the shift ratio of your Huret rear mech is, but Campag's is less than 1.7 so they definitely won't help.
The third is to adjust/modify the stem shifter to give you another few mm of cable pull there. The rear sprocket pitch of an 8 speed is 4.8mm, so only a couple of mm at the shifter would probably suffice.
:troll:
