nmfeb70
- Tonypandy, Wales
The cable was Shimano. I've never had this problem with Clarks cables in the past so maybe I'll go for those with a spray of GT85 in future.
During lockdown one, I didn't have access to a pair of decent cutters so I improvised with a pair of pliers I got from Lidl a couple of years ago.With a top quality pair of Draper cutters. It was as clean as a whistle.
Kinks will do it. Anything which increases friction won't help.A probable cause. There are a number of kinks in the cable the same distance apart.. Shimano use zip ties to keep the cable tidy in the packaging which without a doubt causes this. From what I remember Clarks pack their cables in a cardboard package with no ties.
Is that front or back or both?Little tip that I always do when fitting a new mech cable is to hold the mech firmly and then change gear a just a couple of clicks with the shifter.
not only does this pre-stretch the cable but it pushes all the end caps/ferrules into place.
I also tighten the cable with the chain on the second smallest cog and then adjust it out so it easily moves to smallest gear. This way you get much smoother indexing.
I set the small cog limit before I attached the cable last week when I fitted the new rear mech (as per Shimano instructions").This is rear
but same principle applies to front, and I know it’s obvious, but set the limit screws without the cable attached.
Great outcome. Which Clarks cable?I fitted a Clarks cable this afternoon
Universal stainless steel cable with housing.Great outcome. Which Clarks cable?
?? https://www.halfords.com/cycling/bi...s-universal-inner-bike-gear-cable-239608.html (£2 - stainless steel)
Problem hopefully solved. I fitted a Clarks cable this afternoon with a bit of GT85 and it slid smoothly into the new housing. A little indexing followed by a ride and everything seems ok (although the housing could be slightly longer). I'm disappointed with the Shimano packaging though - a top brand making a p*ss poor mistake like that.
Oooh. What grade of stainless steel was it?Universal stainless steel cable with housing.
Yes I know, I usually purchase them from eBay but my other bike is off road until I replace the shifter so I wanted the cable asap. I only buy tubes from Halfrauds, otherwise I don't go near the place.What pissed me off, was having to pay £30 at Halfords six months ago for one half of this which cost me £17 from Clarks direct two weeks ago.
It's a front and rear disc brake set with calipers, discs, inner cables, outer cables and a spare set of disc pads for both front and back, for £17.00.
Crazy.
Living where I Iive, there really isn't a lot of choice. The local bike shop wants a kings ransom for a pair of brake pads and they won't let you out of the door until you've purchased a £2000 bike with an extended warranty.Yes I know, I usually purchase them from eBay but my other bike is off road until I replace the shifter so I wanted the cable asap. I only buy tubes from Halfrauds, otherwise I don't go near the place.
