Linky?one of the new LCC approved lanes at Kennington Oval (narrow, no priority at junctions, built over what used to be public space) will be mandatory. Watch this space......
really? Can you tell that the the Cheam and Morden, who use it regularly?
You are seriously endorsing this c**p as a "model example":
https://goo.gl/maps/DcIlg
It is all very well showing a photo of a stretch of cyclepath in open countryside with unlimited space and away from junctions (and even then the width is substandard for a 2-way path). But when they encounter the slightest difficulty - ie any side road junction - the path simply evaporates to the sort of nonsense that even the most ardent supporters of segregation would denounce.
I think we agree.A model example. And the surface is in good condition and reasonably clear from debris, and except for the fifty yards past the ramp down to the underpass at West Humble, it's nice and wide too. It's I guess, three miles long. In that three miles:
- It does not have priority over side roads. There are about five turnings where in principle you might have to give way; in practice, good sight lines and low traffic means there's only one where your flow is significantly interrupted.
- If you want to turn off at Burford Bridge to climb Box Hill, it's a bit of a nightmare. They do their best to force you into the horrible underpass (complete with anticycling barriers); if you resist that, you are trying to join then cross a flow of traffic on the dual carriageway from a standing start - significantly harder than being part of that flow to start with.
- At the North end, it's cut off from the more recent continuation cycle path into Leatherhead by a dual carriageway roundabout. Headed north, you can filter into the traffic on the roundabout, but headed south, if you try and do it from the roundabout, there's a ridiculous acute turn, so you almost have to cross Young Street in two manoeuvres at the pedestrian island
- At the South end, it joins onto a typical bodged-from-the-pavement inadequate path into Dorking.
My point? Even a purpose-built, model facility, which has several good points, is not exactly an unmixed blessing.
No, I do understand the point about the CTC's objections and their consequences, or at least I think I do.You miss my point slightly - the Mickleham by pass (to give it its proper name) cycle route, separate from the road, was built in the late 1930's as an trial/example, but CTC objections meant that not only was the model never taken forward but all the associated thinking and planning around junction priorities etc was abandoned also, the result was an orphaned section of facility that has been ossified ever since and never improved or rolled out as the model it was intended to be.
So yes, the links at each end are pretty crappy and the priorities at the few junctions along it are wrong but that is because we are looking at a frozen 80 year old concept. Whereas Denmark (see the up thread comparison) has implemented a coherent strategy of off road/segregated facilities (as have the dutch, Germans, Swiss etc) we have to share road because that is was CTC at the time demanded.
The shared road and no separate facilities (as per the continental examples) we have now is what we asked for.
Even now there is outcry against compulsory use of facilities whereas in Germany wherever facilities are built to the standard required by the German (equivalent of) CTC cycling on the road is illegal ditto in the netherlands.
But just for that stretch of new-build bypass, someone tried to build a model cycle facility, and it still has distinct limitations. It's fairly wide, and it is reasonably well maintained and not covered in glass, and those are features that could be have been rolled out across other new-build facilities. But even this short stretch of new-build doesn't crack the problem of priority at side roads (it's just lucky there aren't many of them) nor of what to do at the ends when you are deposited back onto normal roads.
Even if there had been no opposition and this model had been rolled out more widely, it's hard to see how that would have addressed those problems. I take your point that the attempt even to find solutions was abandoned, so we'll never know what might have been possible - but I am sceptical. You can solve some problems by acquiring more land and pouring more concrete, which is what the A24 cycle path shows can be fairly successful, but solving cultural problems about the existing road network is rather harder.
So, to look at that slightly differently, we can thank the fore-sightedness of the CTC in maintaining our access to the road network.
This.So, to look at that slightly differently, we can thank the fore-sightedness of the CTC in maintaining our access to the road network.
I'm not sure mandatory means what you're trying to suggest it means and it's still public space, but "LCC approved", really? When I last checked in https://www.cyclechat.net/threads/k...ishness-now-its-personal.180432/#post-3704402 they hadn't approved or rejected them.one of the new LCC approved lanes at Kennington Oval (narrow, no priority at junctions, built over what used to be public space) will be mandatory. Watch this space......
Ah-ha! Mr. Jay exists purely and simply in order that I don't have to invent him.I'm not sure mandatory means what you're trying to suggest it means and it's still public space, but "LCC approved", really? When I last checked in https://www.cyclechat.net/threads/k...ishness-now-its-personal.180432/#post-3704402 they hadn't approved or rejected them.
Why on earth would you doub't it? It look like excatly the sort of thing the LCC is campaigning for."LCC approved", really? When I last checked in https://www.cyclechat.net/threads/k...ishness-now-its-personal.180432/#post-3704402 they hadn't approved or rejected them.
I doubt it because I can't find any unreserved approval from them. CCers can make whatever wild claims they like about LCC, but I'd rather see the source. I've been misled far too often while campaigning, so I'm very wary now ;-)Why on earth would you doub't it? It look like excatly the sort of thing the LCC is campaigning for.
What would we prefer:
The British model of sharing the roads and no cycle provision?
or
The Dutch/Danish/German/Swiss model of exensive separate facilities and sharing the road in other areas where there is no cycle facility.
eg
Bicycle infrastructure in the Netherlands[edit]
The Netherlands has thousands of kilometres of cycle paths and cycle lanes, more often the former, and most intersections are considered very bike friendly. Traffic signals are rare on most people's cycle journeys in smaller municipalities (under 120 thousand people) and are only slightly more frequent in larger cities. Most traffic light controlled intersections have some sort of curb to create cycle paths on the junctions themselves, often allowing for turns on red. More intersections are built as roundabouts, most cities give cyclists the right of way over exiting and entering traffic on an annular cycle path, but some municipalities (notably Tilburg and Assen) have chosen to give the motorists the right of way. Cycle lanes usually transition into cycle paths at junctions.
We could have been building that sort of infrastructure since the 1930's but CTC stood agin it to protect the concept of road racing. (TT in particular)
Well, that isn't going to win any design awards (nor is the one at 4m30), but it still seems a heck of a lot better than the multi-lane motor sewers England would usually install in similar situations, doesn't it?my vote goes to the UK. (It starts getting really horrible at the one minute mark)
