sevenfourate
Devotee of OCD
- Lowestoft, Suffolk
@Cadire I worked it out to lose about 1lb in body fat I need to ride about 350miles, because most of the cals you use will be carbs, in my case about a 25/75% split I use about 40-50 cals a mile (figures vary depending which gps recording and site I use) so you can see that it takes a lot of miles, the big plus and this is as important as weight loss is the improved cardio/vascule system you get. My max HR is supposed to be in the region of about 170bpm according to my age, my doc seems to get worried when I tell her I can hit 175 with no issue.
This last month I have done 500 miles and should have lost about 1 1/2 lb's, I don't really weigh myself that much, @sevenfourate you can lose 1-2lb just by going to the loo, daily weighing isn't really a good idea for general weight loss as there are too many variations to consider, once a week or once a month would give a better idea, a normal ride for me of about 2 hrs would see me lose 0.11lb or just over an oz, to small to be really measured on most bathroom scales, my cycling like your walking is about the 900cals/hr, the other thing is the lower the HR whilst exercising will burn more fat than carbs, so a steady flat ride will burn more fat than an intensive one with lots of climbs.
Some of that is informative, interesting and educational (To me at least).
THANKYOU.
I CAN still eat the Mars bars though, can't I?
its difficult to be concise sometimes, real data helps to explain things, but like I said accuracy is a bit hit and miss, and should be mainly taken as a guide
mind you I have just done 114 miles in the last 48 hrs or so, as those other cyclist might have.
