GrumpyGregry
Here for rides.
What's a bus lane? Oima yokel
			Cycles cannot use bus lanes unless allowed to do so. There are a good many places where they cannot and you can get ticketed.The reason being that under the current law cycles can use bus lanes ...
Not exactly the same layout but the road markings are the same -Where in Cambridge has those particular markings? I can't think of anywhere which has that particular layout (which is modelled on the Dutch layout).
I think my post was fairly clear that the issue was about those bus lanes to which cycles were admitted...
Whatever! I think you can join srw in the stalker troll pen...
Ain't just Ashstead boss, south of the A3 they're all on something...all the drivers in Ashtead are on drugs. Fact. Every time I've gone through Ashtead with Agent Hilda I've said 'look out, sweetiepie, all the drivers are on drugs' and every time we've come out the other side she's said 'no s***, Sherlock, they're all on drugs'.
Agreed - me too. The differences include (a) the western A24 cyclepath is a decent width all the way except that short narrow bit over the tunnel at Westhumble and (b) although there are technically speaking give way signs at several entrances along the length, there's enough visibility, and few enough cars using them, that you don't actually have to slow, and you can go all the way from the Givon's Grove to the Denbeigh's roundabout only having to give way once, at Westhumble again. OK, that's once more than on the carriageway, but that's a price worth paying IMO.My (pootling) club cycles down that road occasionally. Usually 8/12 cyclists. Using such a path/crossing is impractical and we will continue to use the road to everyone's annoyance. We are not dogmatic about cycle paths - we use the ones either side of the Dorking bound dual carriageway where the benefits outweigh the disbenefits.
Can a confident 12-year-old cycle safely on the A24. Hmmmm, maybe, maybe not. Personally I doubt it.Thanks everyone (well, nearly everyone) for the helpful responses. What I think I have learned is that for practical purposes you can only give an off-highway cycle path priority over side roads if you've got space to make it cross the side road at least one car's length out from the main road (or if it can be made a one-way side road, which is difficult considering several of these are cul-de-sacs!) That ain't going to happen in this case.
I don't know for certain, because Surrey haven't put out any explanatory material that I can find on their website, but I'm guessing the pressure to do this scheme comes partly from a desire to increase cycling to the local comprehensive. I've got some sympathy that the A24 is a pretty lousy road to cycle on. I do it, and if they put in this two-way, shared-use path with give-ways every hundred yards and trees scattered down the middle I'll carry on cycling on the carriageway, and I'm going to respond to their questionnaire opposing the scheme, but in all honesty, I wouldn't blame a parent who saw it as a step forward.
I don't think cyclists on the path should be required to have to decide to deviate or otherwise. Suppose a car and cycle are approaching the junction at the same time, the cyclist has to decide to go ahead in front of the car or slow down and go round behind the car, ie give way. If a second car comes up to the junction will it leave sufficient space for cycle traffic to pass between the two cars? A lorry or longer vehicle would further complicate the issue. Is it reasonable to require the young and inexperienced cyclist to handle this situation?r, so there's room for a car to be at the junction and for pedestrians/cyclists to go behind without dropping down a kerb. That isn't bending out because the deviation from the straight line is too tight. So pedestrians and cyclists won't deviate unless there's a car in the way.
Less vulnerable road users should be required to give way to more vulnerable road users on any route in any situation perhaps?Motor vehicles should be required to give way to cycle traffic on the main route or cycle path running parallel to the main route..
