mac1 said:
MacB
So, you're saying you can't get the I-Motion repaired locally? Winklebury Cycles (in Basingstoke, just down the road from you) seem to be confident with Nexus and I-Motion. My local Action Bikes messed up the 7 speed Nexus twice on my Dawes Geneva which was then repaired correctly first time at Winklebury.
Yep, Austin at Roman Road, where I purchased hub and wheelbuild, bemoans the fact that SRAM won't authorise, issue tech info or supply internal parts for the I-9. He points out that he's a long established dealer going back through the Sachs days and has years of experience of maintaining their hubs. The UK distributor Fishers told me that SRAM insist I-9's(I don't know about I-3's) are returned to Germany. If it never goes wrong then that's fine but otherwise it's two fingers up to the customers. I highlighted this in an e-mail to SRAM explaining that, with a return to Germany policy, they should be allowing for immediate hub internals swap by dealer/distributor, then doing the return to home bit. No response whatsoever from them.
I'm sure this is all around the internalisation of the shifting and indexing. I watched a video of a Rohloff factory tour and they use some complex 'press' style machinery to seal the internals together.
I'm going to go with the 3 speed SA, I'd prefer it if you could get them with QR axles and clickbox gear attachment. But the little chain isn't that hard and does get easier with practice. Though I will be adding spares of the external bits to my saddle pack, including the indicator chain, just in case
I've even been entertaining thoughts around a 3 speed for big rides. Run it on a lightweight frame with vertical dropouts. Use a chain tensioner with enough scope, and chain, to be able to run a small spread of sprockets. Carry three spare sprockets with you and 10 minutes allows you to regear the bike at any point in the ride. You could even go so far as to carry an entire spare internal unit in case of mechanicals, though that could be a bit anal even by my standards
Whatever, I foresee someone getting a very nice deal on a freshly fixed I-9, in the near future. Though there is a guy on YACF that's owed first refusal on this.
