Following on from the discussion in the stuck BB thread, what does the panel think are the causes of crank bolts loosening and consequent crank loosening?
Some background: We fitted a new square taper chainset to The Boy's bike a week or two back (mid range Trek hybrid, Altura (I think) chainset, slightest smear of grease on the tapers, done up to five white knuckles. The Boy is 22, 6'2" inches tall and stomps his pedals). After a few days commuting (a couple of miles each way) he reported that the left hand crank had loosened. I tightened it up again, using a long allen key. Next day it was loose (or at least the bolt was loose). He now carries a long allen key with him to tighten it.
First obvious thought was that the square hole in the aluminium crank has been damaged by riding with it loose. Is this likely?
Second though is that the bolt is unscrewing but the crank is remaining tight. Is this likely/possible? If so is Loctite going to be a sensible solution?
Third thought is that the crank ismoving further up the taper. Is this likely? How can I measure if it is happening?
