It depends if your pedalling force is a variable or a constant. Most human physical outputs are pretty constant although you can improve with training to a new and better constant. If your preferred pedaling force is constant, then bigger circles are more work. If your mechanical cog ratio is constant, then bigger circles at lower force are the same work.
It is pretty easy and convenient to change cogs.
