Would it not be easier just to change the cassette 39x28=36.63", 34x28=31.94" 39x30=34.19", as would you not need to change the complete chain set, (not to clued up on doubles, compact or not) but are the B.C.D. different on doubles and compacts, and then adjust the height of the front mech.Your best bet would be to change to a compact chainset. This would give you lower gearing without needing to change anything else.
Shorter crank arms won't alter your cadence.
If this is a medical issue (which is it is) and not you just being a pussy, you are forgiven for buying a bigger cassette and if you still struggle, for fitting a compact chainset!
Or you could just avoid the hills for a while longer until you regain
It is medical mate managed fine on all the cat 4 till I had my femur broke and reset doing this they have knackered my quad
They're right, it's the easiest to reverse as well.I've been out shopping today stopped at my local bike shop and he said to keep long crank arms to aid leverage and decrease ratio on the rear to 30 would be very similar to swooping for a compact but at a fraction of the cost
