Coventry Eagle Triple Ace Convertable Tandem.
Illaveago
Illaveago
Here are the pictures from earlier on today .
Reassembling the tandem is going to require some head scratching as to where all of the bits go . I'm going to have to get some loose bearings for the bottom brackets and head bearings .
517337
517340
517342
517344
517345
Gunk
Oxford
Just stumbled across this thread, bloody brilliant, I love it!
.......and I now desperately want one :stop:
Illaveago
Illaveago
There were a couple up for sale a year or so ago . I came across them whilst trying to do some research into my tandem . Not being able to find many examples of them does make it a bit difficult . The fact that the bike can be taken apart makes it easy to transport in a normal car and it was fun dismantling it with the previous owner when I collected it .
biggs682
Northamptonshire
Does the vintage apply to the owner or the bike ? :whistle:
Both i suppose
Illaveago
Illaveago
I've been a bit busy today trying to build up the bike . I started off by trying to fit an inner tube and tyre to the rear wheel . It was a struggle ! I ended up using some washing up liquid and a motorcycle tyre lever to lever it on .
The next thing was trying to find where I had put things . 2 pairs of handlebars should be easy enough to find I thought ! A little while later I found them. They were buried under some other useful stuff.
I had fitted both cranks the other day, I had used recycled some old BB bearings for the time being . I was getting a bit impatient and wanted to see how it looked when built up . I had only seen it briefly in its built up state before dismantling it .
I thought I would start with the front section first with the bars, levers and then the wheel. Fitting the cables was next, and these were very stiff. Some drops of 3 in 1 on the cable and some manipulation had them working . The rear brake cable screws into a bracket fitted underneath the frame and has 2 threaded rods which screw into the end of the cable . Using one or two rods depending on which version of the bike you require .
Once I had built up the front section I could start on the rear . All I needed to do was to bolt in the rear wheel and then I could assemble the tandem . I'm getting better at connecting the two halves together now. It is a bit awkward trying to balance the rear section whilst you slide the front section in , but it is a lot better now the frame has been adjusted.
This is as far as I got to this afternoon . The bike is looking a lot better than when I first picked it up . I will need to get some chains so that i can try it out .
As regards to how many of these tandems exist I can only identify 5 on the internet. The blue and black one in the Coventry Transport Museum, a grey metallic one which was for sale a few years ago, an orange and white one with drop handlebars, an identical one to mine was for sale on Gumtree and mine was also on Gumtree.
517948
517949
517950
517949
