Yesterday I got a blocked/runny nose... took at test and it was negative, so i went to work as normal...
only to discover that three of the people I'd worked with yesterday are all now isolating
Took another test today which to me still looks negative, however a few seconds after I put the drops on the test strip, the entire window went red and quickly faded to white, leaving a very clear negative result behind. The same happened yesterday and I thought nothing of it until i learned some of my co-workers are positive.
There's nothing in the instructions about the whole window briefly going red, and I can't find anything online either.
After 30 mints I've got a clear white background and a clear red line alongside 'C' ...which to me says I don't have Covid and do have a blocked/runny nose... which is a tad annoying.
Are your anti-vax/anti vax passport lot still as vocal as ours ? We had a massive protest in Manchester at weekend. Most of us are like, there are no restrictions, you don't need a vax passport - you are all a little late now !
Nasal only or nose and throat. Apparently the former are a bit less reliable at picking up omicron so do a throat one too. If symptoms but negative LFT, you can get a PCR doneI presume it is just a cold. (or even an allergy*)
*I was absolutely fine until i tried a nasal inhaler from Poundland, then an hour or two later I'm completely bunged up!
However, considering the tests i did before xmas didn't go red first, and i have positive co-workers... there's no harm in asking.![]()
I tested positive yesterday, positive line turned red the moment the fluid got to it. The line is still red now. I had symptoms on Sunday night and Monday but tested negative, luckily I work from home.Our tests go a slight pink colour as the fluid moves up. You'll test positive quickly though - the lines show up immediately from what I've heard. Carry on as normal unless it's positive.
Sorry to disagree. Two tests in our household last November initially looked negative, but after 15-20 minutes went faintly positive.Our tests go a slight pink colour as the fluid moves up. You'll test positive quickly though - the lines show up immediately from what I've heard. Carry on as normal unless it's positive.
Isn't that why they insist/state you must wait the full 30 minutes, before saying it's a negative test.Sorry to disagree. Two tests in our household last November initially looked negative, but after 15-20 minutes went faintly positive.
I think we all know how to do a test and how long to waitSorry to disagree. Two tests in our household last November initially looked negative, but after 15-20 minutes went faintly positive.
Think your link is on the blink!I think we all know how to do a test and how long to wait![]()
It's all going to be irrelevant soon. Will there be any point testing once they take away the requirement to isolate after a positive test? Unless you are honest and isolate despite not needing to. Will employers be supportive of people isolating when not legally required?
