simongrant
Another one of bruyneels former riders,SHOCK?,not me officer
Well that is a real shock. I had never ever suspected that Bertie would get a positive test....
....for clenbuterol![]()
Another thought - Bertie claims it was contaminated meat imported from Spain.... which presumably wasn't just for him. Who else ate it? This should be tracable, and if they were tested they'd also have positive samples. This should help to prove one way or another the truth of Bertie's claim.
We wait and see I guess.
The half life of clenbuterol is ~34 hours. Surely he wouldn't have eliminated a dose sufficient to produce an ergogenic effect by the following day?Personally I'm guessing guilty - if the Voet article is accurate, there was performance improvement for sometime after the drug could no longer be measured. So Bertie takes it on the rest day, hopes it all pisses out, and still has the benefit for the next few days...
I've been wondering about that.Having said that Li Fuyu from Radioshack is still facing a ban (I can't find anything new on his case) for the same level in March this year
Is the difference that Li would not have been tested in the days prior to +ve, and so could not show that *only* the small amount was ever present in his system?
Calls for cycling to be removed from the Tour de France as it's the least important bit
Sums up how the public view racing sadly.
Why "sadly"! The TdF IS an event, a spectacle. You've seen the crowds that gather; at the starts and finishes, lining the roads on-route... they are there to take part in the event. Once it's all passed by, do they look at the results for the day? I suspect most don't. I don't think it's sad, just a more popular aspect of the same event. For me, that's what is humorously spot on about that comment!
Yeah whatever
[spod alert] It's not that small an amount, 50 pg(per microlitre I assume), as it goes- only eight times less than the 'threshold' as stated. Not that I know much (if anything) about PED use but it is easily detectable by modern (in fact not even that modern] instrumentation. Standard specs on instruments even ten years old measure down to the tens of femtogram level. I wonder why there is a seemingly arbitary threshold in use?[/spod alert]
