Compatibile gear shifter, front and rear derailleur?
spartanawoo
Hi Everyone,
I really value your expertise, and I have read and watched a lot of videos on this but don't know the answer. What shifter, front and rear derailleur are compatible with this old Huffy mountain bike?
Appreciate your time!
Nick
si_c
Wirral
Looks like a fairly standard 7 speed setup - so pretty much anything should work as long as it's 7 speed, Shimano Tourney springs to mind.
Any particular reason you are looking to replace what's on their currently?
S
spartanawoo
Thanks si_c for your help... I REALLY appreciate it!!! :notworthy:
The front derailleur is broken and causes the the chain to be permanently stuck on the smallest sprocket. The rear derailleur seems fine (i think) and may just need adjustment but I figured it would be nice to get a nice more modern one like the Tourney. In addition, I am really curious in learning how to replace the whole shifters, cables and front/rear derailleurs. It sounds really fun...however, my only fear is that I don't know what parts are compatible with my bike, hence the reason I am coming to you experts! ^_^
If I replaced the front and rear derailleurs with Tourney, do you think I should or must change the gear shifters? If yes, what gear shifters would you recommend I choose?
Thanks again for your advice si_c! Sooo appreciate it!
Nick
Ajax Bay
East Devon
As @si_c has said the Tourney option offers a 3x7 speed gear system. The shifters slide on the bars (so the grips have to come off first, obv). There's a 'compatibility issue' for the FD which clamps on (probably; there are other configurations) to the down tube. So you need to find out the latter's diameter (measure circumference and divide by pi). 28.6mm or 31.8mm are common clamp sizes. You have a 'down pull' FD (cable comes up from below). Key items to check before purchase.
Your current RD seems to be secured with an adapter claw on the right dropout or it has an integrated one. If the latter, you need to get one like that to replace it (if you need to (why?). If the former, any old RD should just screw in.
Amazon product ASIN B01J4723P4View: https://www.amazon.co.uk/DERAILLEUR-HANGER-ADAPTOR-TYPES-SHIMANO/dp/B01J4723P4
(This is to offer the OP an image, not a recommendation for this item.)
I recommend you keep things simple and replace JUST the (broken) FD, and replace the cables (and outers) as a step towards competence: rather than wholesale replacements.
