Mike Ayling
- Melbourne Downunda
Can't we start calling them clip in pedals?
Is a broken collarbone or farked rotator cuff better than a broken finger, then?
Today I bought a set Shimano SPD PD-515 pedals, 1 damaged but at 0.50 I took the risk on having to bin them.
The damage is a broken off plastic ridged wheel/nut near the pedal mount, likely to open them for servicing.
Question now is without that wheel, if the pedal still does the job. There is nothing metallic damaged, only plastic, including a kinda tube to the inside of the pedal. Can I assume that the pedal won't shoot off or so?
Thank you.
I searched for that term "collar" and found this as description:
"Threaded collar: The threaded collar — or lockring by its other name — is an important component that keeps the pedal body attached to the axle. On budget models, the alloy collar is replaced by a nylon cap. A set of sturdy mole grips or Shimano’s own proper TL-PD40 tool can be used to loosen this. Our super-quick, five minute pedal service will keep your Shimano SPD pedals spinning smoothly for years to come."
So it's a lockring principle, from what I can understand from it, likely it was tightened and in that state the cap and some part of the collar broke off. In that case, I could use the pedals.
I'm sure you know why they are called clipless pedals, but if you think about flat pedals or mtb pedals, they are also without clips. So perhaps we do need a new name for them. I suggest they are called "Click in" pedals to avoid any confusion/association with toe clips.Can't we start calling them clip in pedals?
I like to refer to them as cleated pedals & shoesCan't we start calling them clip in pedals?
Yes YOU do. Anyone new to cycling won't have the foggiest. I prefer "cleated pedals".Just embrace the illogicality of language. We all know what clipless pedals are.
But we had cleats with toe clips and straps.Yes YOU do. Anyone new to cycling won't have the foggiest. I prefer "cleated pedals".
Yeah but not always. Now the cleats are the only thing left.But we had cleats with toe clips and straps.
Different type of cleat, relying on a different "locking" method. Also part of a system, not a system on their own.Yeah but not always. Now the cleats are the only thing left.
