Clipless Pedals FAQ
Dogtrousers
Lefty tighty. Get it righty.
I don't know which I unclip first. I'll have to look next time.
I push off with my right and clip in my left second. This may be due to the fact that my left leg is significantly weaker than my right due to an old injury and operation. Or it may be just because that's how my feet prefer to do things.
My feet are very much in charge of what happens with the pedals and don't take kindly to me meddling in things that are none of my business.
DSK
After 6 months of going clipless without having any clipless issues...….
Today I went down. I don't know why my brain lacked co-ordination but, 1/2 way through my usual training loop I was oddly feeling wacked out, so decided to stop for a few seconds after a hill sprint. As I came to a stop, I unclipped my right foot without issue, only to think, hang on, I wanted to unclip my left so I can put that foot on the pavement/kerb (as the bike slows to a dead stop). As I begin to try and unclip the left, my body begins to lean to the left to initiate an pathetic tumble towards the pavement. I put my right foot on the floor in the process of falling, avoiding the bike making any contact with the tarmac.
Main thing is, it was 06:30 on a bank holiday morning so no one saw me :tongue:
A quick drink, a few swear words at myself prior to finishing the loop:bicycle:
Gazjacko
Whatever you do just remember that if you can’t unclip your shoulder is better to land on than your outstretched hand ! 521572
Twilkes
Okay, what is the dirt-cheapest pedal-shoe combination I can try out? I've never felt the need to ride clipless as I get more than enough grip with flat pedals and actually quite enjoy being able to tweak my foot position based on ride conditions, but I'm curious to see if it would do anything measurable to my riding.
I could probably get some second hand pedals but maybe new shoes to avoid any hygiene issues. Unless Decathlon or Sports Direct stock some budget clipless pedals?
LeetleGreyCells
Un rouleur infatigable
If you're wanting an SPD set-up, then these shoes are cheap from Sports Direct - but shop around as you can usually get better on offer. For pedals, get M520 SPD like these - you can usually find some second hand or shop around as they're usually on offer somewhere. If you do get new M520 pedals, they come with SH-51 cleats which are standard cleats (twist heel out to release from pedal). If you find these too difficult to use, then buy the SH-56 multi-way cleats which allow you to release your feet from the pedals by pulling out in any direction.
If you are wanting lighter, road-specific then it's SPD-SL. Get the yellow cleats for your first time using as they give the most amount of float (allowing you foot to move slightly on the pedal when clipped in, this helps for comfort).
SPD take two-bolt cleats, SPD-SL are three-bolt. Some shoes are specific where you can only use one type or the other. You can get shoes that have holes for both systems.
Gazjacko
SPD enable you to walk properly when off the bike as they’re recessed. As a cleat system, I prefer Crank Brothers pedals and cleats on my other bikes, they’re just easier to uncleat in my opinion.
ianjmcd
PAISLEY
I always used clipless but after 8 years off the bike i started back using flat pedals and trainers and was suffering due to hot foot so I invested in spd-l pedals and a pair of van rysel carbon soled shoes from decathlon first time out on them yesterday rode 45 miles no hotfoot more power and a lot more comfortable and not one clipless moment (the more power is maybe perception because I'm getting fitter though)
Newcyclist67
Scotland
As there seems to be a fairly steady stream of questions on clipless pedals I thought I'd put something together as a beginner friendly introduction to the world of Clipless Pedals and Shoes.
Perhaps this could be Stickied in either the General Cycling or Kit and Clothing sections?
What are Clipless Pedals?
Despite the name, clipless pedals are pedals which you clip into…. the pedal has a mechanism which binds to a specially designed shoe and "locks" your feet in place. The "Clipless" bit actually means you don’t need to use the traditional toe-cage and leather strap arrangement to hold your feet in place.
The clipless mechanism works much like ski boot bindings. To release the clip, you twist your heel outwards, and the bind releases. This ensures that in the case of an accident the shoes release automatically, and means you can
(with a little practice) unclip easily rather than having to bend down and release a buckle (as on the traditional toe-clip).
Should I Go Clipless?
It's a personal decision. There are Pro's and Cons on both sides of the issue.
Clipless pedals offer a more connected feeling to the bike, the shoes are generally stiffer soled than normal shoes, and this can help with efficiency and comfort on longer rides. Arguably clipless offer some power advantages over flats/clips and most, but certainly not all people who try a clipless pedal never go back to toe-clips or flats.
The drawbacks include the expense of the shoes/pedals and in most cases the loss of flexibility. The fact you're limited to a particular pair of shoes may not help. The pedals also need to be set up correctly, incorrect positioning can cause knee and/or ankle pain, some people seem to be more susceptible to this and never get on with clipless systems.
What Are the Different Types of Pedals/Shoes?
There are two "families" of shoes/pedals. Various different manufactures produce pedals/shoes but they almost all fall into one of two types, Road pedals (such as SPD-SL, Time, Keo) or Mountain Bike style (SPD, Crank Bros). The two styles both use a metal or plastic cleat fastened to the sole of the shoe. Most shoes will be designed to accept only 1 of the two types of cleat although there are a limited number of shoes which will take either.
Mountain Bike (Mtb) pedals and shoes - usually referred to as SPD shoes use a 2 bolt system to fasten the cleat to the shoe. The cleat itself is a small triangular metal wedge. The cleat is generally recessed into the sole and the shoes often have a treaded sole suitable for walking in.
Road Bike (SPD-SL/Look) pedals and shoes use 3 bolts to hold the cleat on the shoe. The cleats themselves are much larger than SPD cleats, and made of plastic. They stand proud of the sole and are very difficult to walk in. The shoes are usually light weight, with completely rigid, smooth soles.
Which Pedal system is Best?
Each type has pros and cons. There is no "best" system - simply one which works best for you.
SPD systems are traditionally thought of as the mountain bike solution, although many riders choose to use these on road bikes. The cleats are designed to be recessed into the shoe. This enables the shoes to shed mud better, and also to allow you to walk almost normally.
The pedals come in many designs. Many are double sided, meaning you can clip the shoe into either side of the pedal with minimal fuss. Some have a clip on one side and a traditional flat pedal on the other allowing normal shoes to be used if required.
The shoes themselves also run the full range from SPD compatible sandals through to incredibly stiff "race style" shoes. In most cases however the shoes will be stiffer than normal walking shoes (although not as stiff as a full road shoe).
SPD's tend to be easier to clip into than Look pedals, especially the double sided designs. The smaller cleat and pedal can give less support to the sole of the foot, and some riders complain of "hot foot", an unpleasant burning sensation on longer rides.
Look/SPD-SL (road pedals) are single sided, and have a large flat pedal surface and an equally large protruding cleat design. The pedals can be rather hard to clip into, but offer a very firm connection and substantial support. The shoes are almost always lightweight race style shoes with reinforced nylon or carbon fibre soles with no flexibility at all. Walking in these shoes is difficult at best, and also causes significant wear to the cleats, so is not recommended.
As a general rule, SPD shoes are more likely to suit if
(a) You need to unclip regularly - i.e. a commute with multiple lights/junctions.
(b) Want to walk about off the bike to any degree
(c) Want to wear "normal" looking shoes or have the option of a flat pedal in addition to the clips.
LOOK/SPD-SL will probably suit you if
(a) You're doing long distance rides with few stops.
(b) Want the the lightest/stiffest shoes and pedals available
(c) Suffer from hot foot with SPD shoes.
(d) Really don’t want to put MTB pedals on a road bike.
Adjustment/Float and Positioning.
Both types of pedals offer some form of adjustments, usually to the force required to clip in/out of the pedal itself. This is usually a screw/Allen key adjustment that tightens the spring force on each pedal. If you're just starting out down the clipless route it's suggested that you start with the loosest setting that will hold your foot on the pedal. As you perfect the art of clipping in/out the tension can be increased to grip the foot firmer if required.
Both SPD and LOOK/SPD-SL cleats are unclipped by twisting the heel outwards in a flat plane, SPD pedals have an optional cleat design that also allows the user to twist out in any direction (other than straight up). These multi-directional cleats make unclipping easier, but can pull free of the pedal if the tension is not fairly high.
Each pedal will allow a certain degree of "float" i.e. how much lateral foot movement is allowed. SPD types typically allow the most float. SPD-SL float is controlled by using different cleat designs. Cleats are available with anything from 0 degrees (no movement) to 9 degrees of float. The amount of float required is a personal choice, but I'd suggest that anyone new to clipless shoes should probably start with at least some float, until a suitable position can be found.
The position of the cleat on the sole of the shoe will control the riding position. Each cleat system has a limited amount of movement on the sole, and it’s important to get this correct. Trial and error is probably the best procedure, but a decent starting position can be obtained by sitting on the bike and allowing your feet to hang free. Note the angle at which they point in relation to the pedal and try and ensure that this angle is maintained when the shoe is clipped into the pedal. Also bear in mind that the new stack height of the pedal may affect the required seat height.
Clipless Moments.
The majority of people who switch to clipless pedals will probably have experienced the dreaded "Clipless Moment". Approaching the lights or a junction you coast to a halt, forgetting that your feet are now locked to the pedals. As you stop, you frantically try to pull your feet free as you slowly topple sideways to the floor. It's almost guaranteed that this will happen at the most embarrassing time possible, probably when there is a particularly attractive member of the opposite sex waiting to cross the road.
After a while, unclipping will become natural (trust me - it will). But at least initially I'd strongly suggest practicing starting and stopping several times on a nice soft grassy surface; and quite possible repeating the unclip….unclip…unclip mantra as you approach a stop sign for the first few days.
Clipless Moments.
great post, answers all of my questions
Jacktar
Regular
Thank you Kestevan, for that enlightening Piece of information, and I suppose a lot of bikers want the correct gear to suit their style of riding, me I just want to ride and put my feet where ever it feels right on the day, so I don't think I shall be bothering with any sort of clips.
silva
Belgium
Today I bought a set Shimano SPD PD-515 pedals, 1 damaged but at 0.50 I took the risk on having to bin them.
The damage is a broken off plastic ridged wheel/nut near the pedal mount, likely to open them for servicing.
Question now is without that wheel, if the pedal still does the job. There is nothing metallic damaged, only plastic, including a kinda tube to the inside of the pedal. Can I assume that the pedal won't shoot off or so?
rogerzilla
The pedal body could separate from the axle unit, but it's unlikely as there is a lot of thread holding it in. The collars are available as spares, assuming you can get the old one out somehow. It is left threaded on the right pedal, and right threaded on the left pedal. Probably someone didn't know this and forced it, or didn't buy the (very cheap) TL-PD40 that fits the collar and tried molegrips.
silva
Belgium
Thank you.
I searched for that term "collar" and found this as description:
"Threaded collar: The threaded collar — or lockring by its other name — is an important component that keeps the pedal body attached to the axle. On budget models, the alloy collar is replaced by a nylon cap. A set of sturdy mole grips or Shimano’s own proper TL-PD40 tool can be used to loosen this. Our super-quick, five minute pedal service will keep your Shimano SPD pedals spinning smoothly for years to come."
So it's a lockring principle, from what I can understand from it, likely it was tightened and in that state the cap and some part of the collar broke off. In that case, I could use the pedals.
