Cleaning the tiles on a roof
cycleking
An cold-caller type person knocked on my door this morning, asking me if I wanted to have the tiles on my roof cleaned.
He said that the algae that builds up will damage the roof, or words to that effect. Being polite, I responded that I did not think algae damaged tiles. He then asked me if I had seen the roof of the house three doors down. :smile:
Well yes, I have, surprisingly enough. They cleaned it. But now instead of being dark red tiles, they look a lot paler. This looks to me like they have been abraided/scratched/scuffed/damaged. I thought the algae was from bird droppings when they (the birds) perch on the tv aerial.
Is the cleaning process causing more harm than good?
I am concerned that elderly people living on their own would be bamboozled into having "work" done, that in addition to not being necessary, is possibly detrimental to the tiles.
Your technical advice on this would be appreciated.
yes, it is true that moss can damage a roof this is because over time it can hold alot of moisture which can leak into areas of the roof and cause decay and erosion, in colder months the water will expand and cause further damage. This is why its important to maintain the roof on your property! some insurance companies will even deny claims if you dont have receipt for maintenance of your home. you should scrape the moss off using a roof scraper https://roofscraper.co.uk/ which is a tool specifically made to remove moss from roofs I recently bought one to clean my bungalow roof. it is hard work though!
midlife
Is this thread over a decade old?
MontyVeda
you do know the difference between moss and algae, don't you?
edit... it's probably lichen anyhoo:rolleyes:
When I was a young teenager I used to work for my uncle on weekends and holidays as a jobbing builder. He wasn't that keen on heights and used to get me to do a lot of roofing works such as repointing chimneys, changing slates and renewing lead flashing.
He was a bit of a shark and used to get me to take off slates, turn them round and refit them so they looked like new from the ground. I also had to clean lead flashing with wire wool so that also looked like new. He knew that people would not climb up on to the roof to inspect it.
Looking back, I am ashamed of it but it has taught me never to accept a builder's work without checking it.
newts
Isca Dumnoniorum
Your roof is much more likely to have leaking issues after the travellers (professional roofers) have been at it with a pressure washer removing surface algae together with cracking several tiles in the process of trampling all over. Last year our neighbour had the same professional treatment on her lovely printed/coloured concrete 10 year old driveway. Now it has lost all its colour, integrity & resembles the Sahara desert with the new powdery surface 😔🙄
N0bodyOfTheGoat
Hampshire, UK
Holy thread revival Batman! :eek:
Yesterday, we had a random bloke knock on the door looking for gardening work, in the middle of summer! Normally we wouldn't answer the door, but we were expecting deliveries, so politely declined and off they went to knock on the doors of neighbours...
A few hours later, I emptied our kitchen bins and found a ~6"x3" bit of paper selotaped quite neatly on one edge to the inside of one wheelie bin, simply with "£2" written on it. Very odd!
Better half said note was nothing to do with her, so a bit of googling later, note brought inside for a photo and we've reported the incident online to the local cop shop so it's on record.
Presuming the note was them, google suggests it's some sort of test and "£2" is some sort of code used by these wronguns.
These cold callers usually want you (typically a vulnerable retired person) to do is agree to some work, they do a carp job and demand a fortune for what they did.
Homers Double
To add fairness to a decades old thread we DID have our roof cleaned a few summers ago. NOT because I was bothered about the life of the tiles but the fact that moss was constantly falling into our garden from it and I was fed up of picking it up.
They were probably pikeys but for £150 or whatever it was I wasn't going up there risking my legs.
MontyVeda
that was the birds removing the moss for you for free.:rolleyes:
