Cleaning my road bike......
roadracerash1
Nottingham
1. Car shampoo and your cleanest car sponge.
2. Wash off all the dirt off the frame.
3. If you need to clean your chain I usually put some chain cleaning fluid on it and leave for a while. (i personally use some good degreaser for the chain).
4. Use a chain cleaning tool (or a soft brush). And take all the gunk off.
5. I then use a wheel cleaner and remove the dirt off the tyres. (im a neat freak when it comes to my road bikes).
6. I use some car polish on my frame and use a microfiber cloth.
7. Lightly regrease the chain with some chain lube. I personally prefer GT-85. It leaves a really nice smell. Its surprising how little lube you need for the chain. You dont need to go mad with it. Oh I've noticed that WD-40 isn't a good chain lube. I'm sure its a degreaser.
Pauluk
Leicester
Roscoe said:
On a related note, I keep my bikes in a shed which is slightly damp. How do you prevent the shiny bits rusting?
Got a 6 year old mountain bike in their which gets regular use and cleaning, however, bolts and other shiny bits are a bit rusty looking now. Don't want my new Carrera TDF going the same way after a few years.
I change my bolts, screws and grub screws for stainless steel ones, they cost pennies from my local screw specialist.
Ozzrahog
Tyne & Wear
I am into deatilning my car so want to kepp my bike to teh same standard so I am looking at the following cleaning
1. Wash non oily bits with good quality car shampoo 2 bucket method with microfibre mit
2. Seal paint work with wax
3. Chain/gears degrease and lube
4. Lube break levers, cables etc
5. Lube brake discs (ok joking about that HONEST!!!!)
Am I missing anything ? and what degreaser and lubes do you guys recommend?
smutchin
Cat 6 Racer
The Red Enclave
I don't clean my bikes nearly often enough, so when I do, I have to do it properly...
A couple of weekends ago, I gave my nice road bike a thorough clean. This meant stripping the bike down, removing the front and rear mechs, the cassette and chainset and giving them all a good soak in penetrating oil - it was the only thing I could find in the garage that was strong enough to get some of the gunk off.
Next time the weather is nice enough to take it out, I expect to be significantly faster...
d.
cyberknight
If its really mucky then its car wash stuff in a bucket using old cloths and an old toothbrush nd take the wheels out to clean inside the rear triangle/ forks, for a quick clean you cant beat baby wipes .
musa
Surrey
If your mickle-ing your chain use wd40 first (sprayed on a cloth) rotate the pedals backwards and wrap cloth around chain to degrease. Then lube chain with chain oil or gt85 wipe excess.
NB: wd40 is a Water Dispellent
Ozzrahog
Tyne & Wear
Didn't realise WD40 was a degreaser, always thought it was a lube (got a feeling I am opening a can of worms here!!)
smutchin
Cat 6 Racer
The Red Enclave
WD-40 is too thin to work well as a lubricant, but it is good for cleaning.
GT85 is also a good cleaner and is a bit better than WD-40 as a lube, but still a bit lightweight for my liking. I use GT85 or bogstandard generic "bike oil" from the LBS to lube moving parts like brake pivots, front and rear mech, but never GT85 for the chain - for that I use Finish Line.
d.
Peteaud
South Somerset
I use Zaino Z8 to finish but have also given it a coat of Dodo SN i the past.
Trim cleaner under the saddle is good (dont put it on the top tho)
