Also, chain-wise I'm happily Mickling away on my old bike currently and am planning to do the same on my new ride, but as I'll only be riding it in dry conditions was planning on using dry lube on this one instead of the bike oil I use currently. I know this is probably a daft question, but will Mickling still work with dry lube? I can't see how it will, but then I haven't used dry lube yet so am not sure what it's like.
I use dry lube in all conditions, because I hate the mess of conventional lube.
Best advice I can give is to
1. degrease the chain with some white spirit in a large (e.g. pasta sauce) jar
2. rinse in a second jar of white spirit and keep both jars of white spirit for future reuse
3. hang the chain to dry somewhere the white spirit fumes won't bother you
4. Install chain and apply dry lube
You don't really need to wipe a dry lubed chain. The excess flakes off on it's own, taking dirt with it. Although periodically you should strip the chain with white spirit and start again.
Don't be tempted to apply the dry lube over conventional lube without degreasing first. It won't adhere properly, and then you'll be complaining that dry lube doesn't work, and go back to the unnecessary mess of conventional wet lubes.
