Andrew_Culture
Internet Marketing bod
- The People's Republic Of Suffolk.
and dont forget the show us your giant thread!!!
I have no idea why, but I can't find it!
http://www.cyclechat.net/threads/show-off-your-giant.96532/I have no idea why, but I can't find it!
I'l bear that in mind thnxNice one. wishing you many happy miles on it.I have the same pedals.If you havent used spd Pedals before make sure you adjust the pedal to its loosest adjustment until you get used to them. This allows easier release if you have to stop in a hurry or the chain comes off or some other mini disaster occurs while you are clipped in.
Just bought the crud road racers mk2 from CS for...£21.50!!! Result all around i say!!! :-)ONLY the Crud road racer Mk2s will fit and they are an utter pig and rub a bit, nothing else will unless you want the ugly MTB ones that clip on the seatpost. The guy tried 3 different types for my Avail which is basically the same
http://www.chainreactioncycles.com/Models.aspx?ModelID=54934&gclid=CND5zNGQ5bECFcIPfAod0GIAmg Buy from the LBS and get them to fit the buggers is my advice!
Mine rubbed a bit on my Defy 2 2011 until I changed the tyres to 23mm and now they are fine. I think the 2012 model comes with 23mm tyres so they might be good to go.Be warned they will most likely rub and rattle but you'll have a clean backside !
When you change the tyres pop 23s on instead?I think the Avail is on 25s
They are ok on one side, but rub the other - any tips to make them stand proud on both sides. They do seem a bit flimsy, but then they are light and were free!
Yep, 2011 defy had 25mm tyres whereas 2012 hav 23mmm!!!Mine rubbed a bit on my Defy 2 2011 until I changed the tyres to 23mm and now they are fine. I think the 2012 model comes with 23mm tyres so they might be good to go.
