Geoff Crowther
"... travel far, not fast", Ted Simon
- Hayfield, High Peak
Cheers. Here you go then:Send us a photo of the entry and exit points and lets take a look. The cable HAS to have a housing. It is there somewhere.
First, entry point where rear brake cable goes into front of top tube. You can see the alloy ferrule at the end of the outer, showing that it ends where it seats in the frame.
Next, this the point where the rear brake exits the back of the top tube. There's a plastic moulding surround the hole.
And this is where the gear cables go into the top of the downtube, one on each side. Again, there seems to be a ferrule at the end of the outer, just inside the frame.
Finally, here's where the two gear cables come out at the bottom of the downtube.
I have to admit, it almost looks to me as if, once everything's freed off and the outers are out of the way, you might be able to tape the new cable to the old and pull it through. What do you reckon? Everything I've read via Google refers to the use of thin tube straws fed over the existing cable before removing it.
